Another stupid question
  • Lazyman06
  • Lazyman06's Avatar Topic Author
22 Nov 2014 16:47
#654414
Is the snap ring a necessity for the wheel bearings. It seems as though the bearing would stay put without it. Reason I'm asking its a pain in the a$$
1979 KZ1000 MK II frame
1980 KZ1000 C3 police engine
Re: Another stupid question
22 Nov 2014 17:04
#654415
Yes, put them in. They ensure the bearings are seated at the correct depth and that they stay there. Ed
  • SWest
  • SWest's Avatar
  • 10 22 2014
22 Nov 2014 17:59
#654419
Yes to prevent undue stress on race or bearings.
  • Lazyman06
Re: Re:Another stupid question
23 Nov 2014 07:21
#654439
I was afraid y'all were going to say that :P
  • martin_csr
  • martin_csr's Avatar
23 Nov 2014 07:54
#654440
Just curious. What's the difficulty? No the snap ring pliers?
  • Lazyman06
23 Nov 2014 17:47
#654477
No snap ring pliers, and 30 yr snap ring that hasn't been removed
  • kaw-a-holic
  • kaw-a-holic's Avatar
23 Nov 2014 18:05
#654478
Lazyman06 wrote: No snap ring pliers, and 30 yr snap ring that hasn't been removed
do you have a Harbor Freight near by?
starting under $5
www.harborfreight.com/catalogsearch/result/?q=snap+ring+pliers
Jon
1977 KZ1000a1
Mesa, AZ
Phoenix Fighter Project
  • SWest
  • SWest's Avatar
  • 10 22 2014
23 Nov 2014 19:34
#654480
I got a cheep assortment at OR for $15. I once used a pair of sizzors and used small screw drivers, even ground needle nose pliers to work. Not worth it unless it's the only time. :whistle: I can't tell you how many tools I've lost to tool thieves over the years. I have a special place in my heart just for them. :angry: Steve
  • Lazyman06
24 Nov 2014 11:04
#654516
Bought some harbor freight snap ring pliers and the tit broke the first time i used them.
  • SWest
  • SWest's Avatar
  • 10 22 2014
24 Nov 2014 16:53
#654545
Like anything that's been in there for a long time. A few taps with a hammer and screw driver the get it loose or with Phillips screws a hand impact. Steel and aluminum don't like each other or maybe too much, that's why they seize.
  • kaw-a-holic
Re: Re:Re: Re:Another stupid question
24 Nov 2014 17:26
#654551
Lazyman06 wrote: Bought some harbor freight snap ring pliers and the tit broke the first time i used them.
Sorry about that, I have been using the same pair I got there for 4 years with no issues.
Jon
1977 KZ1000a1
Mesa, AZ
  • martin_csr
25 Nov 2014 06:56
#654588
That's the risk of buying cheap tools. Sometimes they work fine, sometimes not.
Try an auto parts store. autozone's look the same as the HF pliers. I use a Lisle set from o-reilly.
