Just starting out
  • Rocky21
  • Rocky21's Avatar Topic Author
Just starting out
06 Sep 2014 15:46 - 06 Sep 2014 18:24
#646447
Hello everyone
I just got my 82 ltd 440 this is a running bike. But not to much else good to say about it. I plan on taking it apart and doing some kind of bobber cafe racer hybrid thing not sure yet. Lots of ideas bouncing around. I have a spare front tire and was wondering if anyone has tried to use this as a rear tire to give it that skinny look also what swing arm are out there to strech out the back end alittle. Thanks I will post picks soon
Last edit: 06 Sep 2014 18:24 by Rocky21. Reason: Add pictures
  • DoctoRot
  • DoctoRot's Avatar
Re: Just starting out
06 Sep 2014 19:00
#646496
Front is a 19" wheel rear is a 16" tire will not fit.
  • steell
  • steell's Avatar
06 Sep 2014 19:03
#646498
Where's the emoticon of a man pounding his head into the wall when you need it?????????
I'm a 63 year old gear head, you're looking for a 17 year old answer. The best I can help is to go fix myself another drink and check on my pizza.
06 Sep 2014 19:12
#646501
A 19" tire on a 16" rim might be just a tad loose. :laugh: :laugh: :laugh: :laugh: :laugh: Is joke - no? Ed
  • Topper
  • Topper's Avatar
07 Sep 2014 06:15
#646541
Play nice. He didn't say the spare front tire was for the same bike. Maybe it's a 16" front tire? Maybe he just didn't bother to check. Either way, let's offer as much help as we can.
The rear tires on these old KZs tend to be pretty skinny by modern standards. Most folks try to put wider rear tires on for better handling and longer wear.
In general there are some tires you'll see sold as front/rear. But I wouldn't put a front only designed tire on the rear even if it fit. The tire profiles tend to be pretty different. Rears are flatter for more stability and fronts are optimized for steering. I seem to remember hearing you also have to reverse the rotation direction if you do this, though I'm not sure if that's true or why it would be.
But in general I think the answer to your question is that this is not a good idea.
Permanent and perpetual noob.
1979 KZ750 Twin
2009 Kawasaki Versys
07 Sep 2014 06:56 - 07 Sep 2014 06:57
#646545
You're correct, he did not say the front tire was from the same bike. However, I do not know of any motorcycles that came with a skinny 16" front tire (16" is the rear wheel size), so I still believe he is referring to a tire that is for the front of the same bike. If I am wrong maybe he will provide more specific information. Ed
Last edit: 07 Sep 2014 06:57 by 650ed.
  • Rocky21
07 Sep 2014 07:10
#646550
Thanks guys. I appreciate all the great sarcasm I guess I should have said the rear tire and rim. Sorry to bother the experts with my silly questions. But I will have many more to come as I am just starting out. Also. I posting from my iPad but when I try to add photos nothing happens.
  • floivanus
  • floivanus's Avatar
07 Sep 2014 07:53
#646556
No, you really cant use a front wheel as a back. There isnt any way to mount the cush drive and sprocket, why would you want to do that? In general front wheels can only go on the front rear only on the rear.
Past; 78 kz1000, 83 kz550
Andrew
  • LineArtist
  • LineArtist's Avatar
07 Sep 2014 08:04
#646559
Hi Rocky and welcome.
All I'm going to say in this introduction is to get to know your bike FIRST. Get a Kawasaki factory service manual on ebey and look through it. When you are ready wrench that bike until it is running good and strong. Then ride it to understand how it handles the road. Ride it some more, wrench it plenty, Ride, ride, ride.
After about 500 miles you will probably come back to the forum with a different perspective. I think your bike would make a great bober/racer but unless you understand it, your journey will be nothing but an uphill battle without the results you have in mind.
Do you have the airbox?
... just my 79 cents.
'79 KZ650B3 (stock)
'79 KZ650B3 (parts bike)
'06 HD 883R
  • Rocky21
07 Sep 2014 11:22
#646585
Attachment image.jpeg not found
Attachment image-1.jpeg not found
Attachment image-2.jpeg not found
  • Rocky21
Re: Re:Just starting out
07 Sep 2014 13:45
#646592
Thanks lineartist I have already started tearing it down. So riding it around is not an option. I have had bikes before just never worked on one till now But I look forward to learning as I go. Also I do have the air box. Why do you ask?
  • floivanus
07 Sep 2014 15:20
#646604
That bike without the airbox is notoriously finicky to tune and somerimes wont run at all.
I'm asuming you want to put that 650 wheel on the rear to ditch the drum brake IMHO the drum is better looking less prone to failure (get new shoes wont ever lock up) and has less parts to go bad. To swap to a disc you would need a full swingarm, rear wheel, sprocket carrier, master cylinder and a way to mount it, then find a way to adapt the belt to it, or a front sprocket set up. Would be just as much hassle as upgrading to a modern set up.
My take, not worth the hassle to me at least, why my 550 still sports a perfect workingndrum brakemset up
Andrew
