front end
  • 78650
  • 78650's Avatar Topic Author
front end
03 Sep 2014 18:41
#646165
Whats going on people I am new to the site and havea lot of guestions first I have a 78 kz 650 and want to upgrade to a inverted fort style front end I know mods are gojng to have to happen but just need a starting point on what will fit ...thank...many more guestions to come...any and all help is greatly appreciated
  • StreetfighterKz
  • StreetfighterKz's Avatar
Re: front end
03 Sep 2014 19:42 - 03 Sep 2014 19:42
#646180
Best answer is just to start browsing the project section and search the technical section.
It all depends on how much you want to spend for parts and how much work you are willing/able to do yourself.
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
Last edit: 03 Sep 2014 19:42 by StreetfighterKz.
  • steell
  • steell's Avatar
Re: front end
04 Sep 2014 21:40
#646312
And nothing fits, unless you modify it to make it do so. If you're a machinist with a shop full of tools and equipment, it's easy, if not, then much more difficult. :P
  • 78650
Re: front end
07 Sep 2014 07:15 - 11 Sep 2014 10:15
#646551
Steell...I hope everyone on this site is not like you, both your replies you did not need to waste your time, are you a dick all the time......you can answer that guestion...
Let's see three posts and you are insulting long time respected members. I suggest that you step back and consider how your actions might affect your longevity here.
kzcsi
Moderator
Last edit: 11 Sep 2014 10:15 by KZQ.
  • StreetfighterKz
Re: Re:front end
07 Sep 2014 08:59
#646566
I wasn't trying to be a dick but the question of front end swaps and swingarm swaps has been brought up over and over on this site to the point of beating a dead horse at times. (You're new so you're not aware of it ) But seriously, if you search through the project sections you can see how/what was done to get each particular unit to work plus maybe get some inspiration for other parts and way to build your bike up.
I've done a couple frontend swaps and they're documented in my build threads linked in my signature.
Later, Doug
1979 z650 Resto-Mod
2018 Z900RS
  • HBKwaka
  • HBKwaka's Avatar
Re: Re:front end
07 Sep 2014 10:22
#646577
Other than looks wat is the advantage to inverting the forks? As far as a mechanical engineering stand point it seems to make the forks weaker. Wat are the advantages?
Re: Re:front end
07 Sep 2014 13:04
#646589
HBKwaka wrote: Other than looks wat is the advantage to inverting the forks? As far as a mechanical engineering stand point it seems to make the forks weaker. What are the advantages?
None that I can think of on a KZ650. Ed
The following user(s) said Thank You: PLUMMEN
Re: front end
07 Sep 2014 14:32
#646594
78650 wrote: Steell...I hope everyone on this site is not like you, both your replies you did not need to waste your time, are you a dick all the time......you can answer that guestion...
Steell wasn't being a dick; he knows what he is talking about. Like it or not, what he said was true as you will eventually find out if you make the modification. Good luck with it. Ed
  • 80B4
  • 80B4's Avatar
Re: Re:front end
08 Sep 2014 16:10 - 08 Sep 2014 16:16
#646741
HBKwaka wrote: Other than looks wat is the advantage to inverting the forks? As far as a mechanical engineering stand point it seems to make the forks weaker. Wat are the advantages?
The larger OD of the female fork tubes provides more area for the triple clamps to clamp to, The end result is a fork assembly that deflects less then a conventional fork. Most inverted, or male slider, forks are built around a cartridge damper which is superior in almost every way compared to a damper rod fork.
If you have the time and money ( lots of money) male slider forks are a great modification for any mid 75s and newer motorcycle. Lots of money!
1980B4 1000
1978 Z1R
1978 B3 750
Last edit: 08 Sep 2014 16:16 by 80B4. Reason: stupid spell check!
  • TexasKZ
  • TexasKZ's Avatar
Re: Re:front end
08 Sep 2014 17:32
#646753
Without a doubt, but at what point does the wonderfulness of the newer forks get overwhelmed by the weakness of the antique frame?
  • HBKwaka
  • HBKwaka's Avatar
Re: Re:front end
08 Sep 2014 18:53
#646765
Great for Kneviel jumps I guess...
  • 80B4
  • 80B4's Avatar
Re: Re:front end
08 Sep 2014 20:43
#646783
Only your wallet knows the answer to that question. I have found that it's the forks and swing arm that cause most of the flex in 70's eara motorcycles. Stiffen those two systems, align the wheels, invest in proper rate springs and modern damping and most (not all) mid 70's and newer bikes handle very well. Especially when they are kept on street tires.
1980B4 1000
1978 Z1R
1978 B3 750
