Upgrade 78 650 B2A to dual front disks
  • ewolpert
  • ewolpert's Avatar Topic Author
28 Aug 2014 20:21
#645537
I am trying to find the easiest way to do this. I know the forks I have already have the mounting holes. Would I just need an additional rotor/caliper and a splitter. I have to replace the master cylinder as it stands.
Any help would be appreciated.
Thanks!
Eddie
78 KZ650 b2a
Re: Upgrade 78 650 B2A to dual front disks
28 Aug 2014 20:24
#645538
Also, keep in mind that KZ dual disk brake systems use thinner rotors than single disk systems. Ed
  • ewolpert
28 Aug 2014 20:33
#645539
So, two new rotors? Would I need different calipers as well?
Eddie
78 KZ650 b2a
  • PLUMMEN
  • PLUMMEN's Avatar
28 Aug 2014 22:02
#645549
You can use 2 thicker rotors if you want,just adds a little weight is all. :)
  • DoctoRot
  • DoctoRot's Avatar
29 Aug 2014 00:39 - 29 Aug 2014 00:45
#645559
I think you can just get a right caliper from a KZ1000 or whatever and swap. you will need a 5/8 bore MC. For street riding dual really wont make much of a difference, but it does look pretty cool. If your looking for better stopping power i would get new pads and stainless lines, and prep the sweep area with sandpaper in a crosshatching patten, then clean with acetone or MEK. Do not use aerosol brake cleaner. Heres my B2 I put a dual setup from a KZ1000 on.
Last edit: 29 Aug 2014 00:45 by DoctoRot.
The following user(s) said Thank You: ewolpert
