Parts for front brake system cleaning
- TheForumTroll
14 Aug 2014 04:31 - 14 Aug 2014 04:32
So I'm going to clean out my front brake system. Would you recommend any other parts to have on hand except these:
43049-002 RING,PISTON SEAL
49016-1041 COVER-SEAL,BRK PISTON
43022-1009 STOPPER-BRAKE,PISTON
92001-1055 SCREW,COUNTERSUNK HED
14008-1035 LINER,PISTON
46092-1026 LEVER-GRIP,MASTER CYL
92015-1191 NUT,LOCK,6MM,BLACK
92001-1512 BOLT,6X37.3,BLACK
Thanks.
Thanks.
-[ KZ700-A1 '84 ]-
Last edit: 14 Aug 2014 04:32 by TheForumTroll. Reason: Spelling
- PLUMMEN
Re: Parts for front brake system cleaning
14 Aug 2014 04:43
Iso alcohol for cleaning rubber parts
The following user(s) said Thank You: TheForumTroll
14 Aug 2014 05:35
I would also try to get the 2 items below. Ed
Attachment 00003_2014-08-14.jpg not found
Attachment 00003a_2014-08-14.jpg not found
- TheForumTroll
14 Aug 2014 05:57
Thanks. I'll wait and see how the piston part looks. It's a tad expensive here. The dust seal is a good idea. I'm good to go then!
-[ KZ700-A1 '84 ]-
- DoctoRot
14 Aug 2014 13:39
braided stainless brake lines are worth considering as well
- TheForumTroll
30 Aug 2014 15:35
Well the shops payment system was broken so the order never went through :pinch: I'm ordering it again now but I'm used to always put in a new bolt when changing oil and was going to add one to my list. it isn't on the parts diagram from Kawasaki so I'm a bit confused. Is it par of the bypass valve?
Attachment Capture.png not found
-[ KZ700-A1 '84 ]-
30 Aug 2014 16:11
Yes, that's the oil pressure relief valve. Ed
30 Aug 2014 21:05
Is this a daily driver or a project? If the later I'd tear down the calipers before ordering parts. The pistons may be pitted and they are expensive. Also, I'd consider new brake lines mandatory. The old lines are almost surely full of crud and scale which will contaminate the system as soon as you fill it with fresh fluid.
31 Aug 2014 05:17 - 31 Aug 2014 06:08TheForumTroll wrote: Well the shops payment system was broken so the order never went through :pinch: I'm ordering it again now but I'm used to always put in a new bolt when changing oil and was going to add one to my list. it isn't on the parts diagram from Kawasaki so I'm a bit confused. Is it par of the bypass valve?
The oil drain plug is in the Breather-cover/Oil-pan diagram.
I can see replacing the gasket each time but not the plug.
Last edit: 31 Aug 2014 06:08 by martin_csr.
