What chain and sprockets are you using?
- TheForumTroll
29 May 2014 15:21
Hi!
My new bike needs a new chain and sprockets so I was wondering what you guys are using?
I'm thinking about swapping the stock sizes out with a smaller front / bigger rear since I don't really need the higher gearing around here (50-80km/h). But how low can I go and what kind of chain? 530?
-[ KZ700-A1 '84 ]-
- 4TheKZ1000
Re: What chain and sprockets are you using?
29 May 2014 16:02 - 29 May 2014 16:13
530 is a great choice. It is done only one way....all new gear.
New Chain
New rear sprocket
New output shaft sprocket
The output shaft nut can be a real bitch to get off. Don't go hammering and getting all backyard redneck on it. If you ever have a problem with the bike, step back, get on forum and ask how to get it done. We are happy to help you.
An EK chain - X or O ring is a good one.
New Chain
New rear sprocket
Last edit: 29 May 2014 16:13 by 4TheKZ1000.
- peter1958
29 May 2014 17:17
This might help you if you are going too change sizes
www.gearingcommander.com/
www.kzzone.com/
- Tomolu5
29 May 2014 18:02
I wouldn't go too crazy as far as getting away from stock gearing is concerned. They set it up from the factory to be predominantly street friendly. One tooth down in the front(or the 530 equivalent) will make a pretty big difference. Any more than that, and you will constantly be on the shifter.
Mine:
04 Honda rebel 250(wifes)
04 GSXR 750(bolt on galore)
98 CBR 600F3(filter, pipe, adjustable cam sprokets, dyno tune)
76 KZ900A (LTD gauge pods, crash bars, LTD(style)pipes, dyna coils and ignition,headwork and mild port cleanup by cavanaugh racing, K&N filter pods, heck I dunno.
- bountyhunter
29 May 2014 18:32
+1 Stock gearing is always pretty low to accommodate heavy loads like riding with a passenger.
- TheForumTroll
29 May 2014 19:09
Thanks. I'll stick to stock or one down.
-[ KZ700-A1 '84 ]-
- gearheadmm
- MUCH MORE BOOST..........I mean BRAVO
29 May 2014 20:08 - 29 May 2014 20:10
The easiest way to get a countershaft nut off is to do it while the bike is still together and put a breakerbar on the nut, sit on the bike, and hold the rear brake while loosening the nut.
Always use the largest countershaft sprocket you can.
The chain will last longer.
Change gear ratio with the rear sprocket.
General Joeseph Dunford FOR PRESIDENT!!!
69.46.28.106/forum/11-projects/413221-80-kz-1000-st-recycled
Last edit: 29 May 2014 20:10 by gearheadmm.
The following user(s) said Thank You: PLUMMEN
29 May 2014 20:58
- bountyhunter
30 May 2014 00:46+1 Easier if you have an assistant. On mine, the torque spec on the shaft nut is about 100 ft-lbs so you need a good breaker bar.gearheadmm wrote: The easiest way to get a countershaft nut off is to do it while the bike is still together and put a breakerbar on the nut, sit on the bike, and hold the rear brake while loosening the nut.
- bountyhunter
30 May 2014 01:03TheForumTroll wrote: Hi!
www.z1enterprises.com/ListItems.aspx?pag...eywords=X+ring+chain
Z1 had the best prices on good X ring chains when I got mine. It's lasted about 6 years so far. They also have the sprockets.
- TheForumTroll
30 May 2014 02:45
Z1 is in the States right? I'm in Scandinavia so I guess that would be expensive. Know any good dealers of parts in Europe?
-[ KZ700-A1 '84 ]-
30 May 2014 05:22
Here are some. Ed
www.nosparts.se/
www.partssweden.se/kawasaki
www.cmsnl.com/search/partnumber.php
www.z-fever.de/ShopNeu/shop/index.php?cP...504530d7dcd4d2d45b07
www.nosparts.se/
The following user(s) said Thank You: TheForumTroll, Ptl1987
