83 kz750l3 swingarm pivot bolt diameter?
- stilkikin
- Why the **** did I do that?
30 Mar 2014 07:30
Is it 16mm? I won't be taking it apart for the swap till I get all the parts in hand. I just want to verify the size so I can order some Nylon or Delrin spacers. Thanks guys!
82 KZ750L
78 KZ650SR
78 KZ650SR
Re: 83 kz750l3 swingarm pivot bolt diameter?
30 Mar 2014 08:20 - 30 Mar 2014 08:21
According to Kawasaki.com it is 16mm. Also, that site shows it being the same diameter as the bolt on my KZ650 which I measured, and it is 16mm too. Ed
Last edit: 30 Mar 2014 08:21 by 650ed.
The following user(s) said Thank You: stilkikin
- stilkikin
30 Mar 2014 15:20
Thanks again 650ED.
If any of you have done the gs1100e swingarm conversion I need some info. I doubt the factory chain will be long enough, how many links did you have on the new chain with the longer swingarm?
82 KZ750L
78 KZ650SR
78 KZ650SR
- stilkikin
30 Mar 2014 15:24
One more thing. I'm going to be using goldwing shocks. Will I need the the mounting hardware for the clevis joints on the lower end of the shocks from a Golwing or the gs 1100e?
82 KZ750L
78 KZ650SR
78 KZ650SR
