Fit a ZRX 1100/1200 swingarm to a KZ1000J?
  • KZ1000J
  • KZ1000J's Avatar Topic Author
09 Mar 2014 14:24
#624628
Is it possible without MAJOR modification?
  • baldy110
  • baldy110's Avatar
Re: Fit a ZRX 1100/1200 swingarm to a KZ1000J?
09 Mar 2014 20:17
#624670
Define major modifications.
  • KZ1000J
10 Mar 2014 07:04
#624700
I don't have any trouble manufacturing spacers and bushings but that's about where I like to draw the line.
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
10 Mar 2014 07:18
#624701
yes it has been done on this board a couple time i know of.
check out cory(nakedfun) build thread.
  • KZ1000J
10 Mar 2014 12:11
#624724
Will do, thanks for the hint!
  • NakedFun
  • NakedFun's Avatar
10 Mar 2014 12:49
#624730
Yes. It is not bad. Main things are:
- Trim 1/8" off the aluminum pivot tube on the non-chain side (RH) and press the radial seal in until it is flush. remove and discard RH "top hat" spacer.
- You will need to space out your upper shock mounts approximately 1" I believe. I ended up welding in new upper mounts anyway so I got geometry that matched the sotck ZRX.
- Lastly, I have included in my thread a dimensional drawing for a shaft that slides into the arm locking it in that uses 2 x 5/8" grade 8 bolts from both sides to bolt the whole thing in. I did this so I didn't have to make a bushing for the stock 16mm swing bolt to adapt the 20mm pivot diameter of the ZRX. This would also have meant I would have to come up with a second spacer to lock up against the LH side roller bearing to prevent side to side movement.
Cory
2008 Kawasaki Concours 14
1999 Kawasaki ZRX1100
1976 Kawasaki KZ900
The following user(s) said Thank You: KZ1000J
  • KZ1000J
17 Mar 2014 07:26
#625527
Thanks a lot! I will try to locate a swing arm now!
  • barney
  • barney's Avatar
17 Mar 2014 09:34
#625540
I have a nice ZRX1100 swingarm includes concentric adjusters and brake torque arm for sale. I want $260 plus shipping from Canada. PM me if interested
