1980 KZ LTD Rear Wheel Swap
- tizon
05 Mar 2014 09:15
I want to swap out my 16" rear wheel with with an 18" wheel. I'd prefer to keep the same style mag.
Does the 1980 KZ1000 or KZ1000 Police swap out without any problems?
- wireman
Re: 1980 KZ LTD Rear Wheel Swap
05 Mar 2014 10:01
Id say a rear wheel off of a 79-80 mkii bike would be a safe bet.
- tizon
05 Mar 2014 18:38
OK Thanks for your input... i did forget to mention it is a kz1000 ltd
- wireman
05 Mar 2014 18:54
Yeah I figured it was an ltd when you said 16" rear wheel, ive had several 1000 ltds in the past.
- Greasedmonkey
11 Mar 2014 15:49
ive got a kz650 ltd that Id like to do this to as well. 18" just looks better to me.
1980 KZ650E
- tizon
14 Mar 2014 19:24
OK so i have been doing a lot of homework on this... :blink: .turns out the only 18" mag that fits on a ltd is the 1978 and 1980 z1r rear wheel. There was no z1r in 1979...I have found a wheel I just need a sprocket carrier .
Does anybody have a 1978 or 1980 sprocket carrier? :S
I already have the bearings...and I will be going with a 130 dunlop
- 2wheelfiddler
14 May 2014 06:39
Hey there,
I'm trying to do the same here, and I'm curious about the choice of wheel.
You say the only possible swap for 18" rear mag wheel is the Z1R. Why is that?
I got my hands on a 18" rear mag wheel, but I'm not sure if it's either from a KZP, a Z1R or if there is another model with the same mag wheel design. Trying to figure out which parts I need to make it fit.
- DoctoRot
14 May 2014 13:24
As Wireman said, the MKII used a 18" rear as well. As do the police models, however I think anything after 1980 will not be a direct swap.
I believe Tizon may be a confused, as the Z1r was the only model to come with a 18" FRONT wheel. the police bikes came with a 18" front as well but it is not a direct swap.
