What tank is this?
- david-b
- I am THAT guy
What tank is this?
06 Feb 2014 12:08 - 06 Feb 2014 12:21
Any ideas? Looking for one to fit my bike, this looks close but I don't know fully.
Thanks
EDIT: Ok well this site isnt working. Keep getting 500 Internal errors. Someone might want to fix that.
Thanks
/Dave
2013 Chevy Sonic LT 1.4L Turbo
1982 Kawasaki KZ750-H3 LTD
1975 Monte Carlo 400sbc
Last edit: 06 Feb 2014 12:21 by david-b.
Re: What tank is this?
the site is working fine,it is trying to tell you that your picture is to large.
resize it to 1089 wide x 817 tall and voila YOU will have fixed that.
06 Feb 2014 17:15Attachment picpostnewsite912x671.jpg not found
- david-b
- I am THAT guy
07 Feb 2014 06:07
Well maybe it's just the programmer in me, but you should say why there's an error at that point, not just come up with a general web error which can related to hundreds of issues. Or implement a function that resizes the image automatically on the server side. Uses little processing power and works. /rant
Anywho, lets try this one.
Attachment Untitled-1.jpg not found
/Dave
07 Feb 2014 06:45
It looks like a KZ550-Ltd fuel tank... the tab is bent.
What specific model tank do you need?
- david-b
- I am THAT guy
07 Feb 2014 08:22
82 KZ750 LTD (H3 if that's needed)
Thanks
Thanks
/Dave
07 Feb 2014 11:31 - 07 Feb 2014 12:02
You should be able to use the tank from the 80-83 KZ750-H Ltd chain drive models.
Also, the 81-83 KZ650-CSR tank should bolt on as well, but the petcock bung may be in a different position on one or two of them, so the petcock may contact the #1 carburetor (the 81 CSR petcock bung is more rearward). A smaller petcock or fuel valve may solve that problem, though. I don't know if the bung location is the same on all of the Ltd models, so be sure to check that prior to purchasing anything.
I think the 80-82 KZ750-E Standard fuel tank will bolt on, but the Ltd upper triple will bang against the E tank. The stock Ltd tripe tree is kinda straight across, whereas the Standard is angled forward. The E tank is ~4.2 gallons. If someone put a GPz front end on your bike, you could check to see if the triple tree is angled similarly to the E, which might then allow clearance for the larger tank (hopefully).
Last edit: 07 Feb 2014 12:02 by martin_csr.
- david-b
- I am THAT guy
10 Feb 2014 06:38
Thanks for the response. I'll continue looking for a 750H LTD tank then and check the petcock location.
Trying to get everything to fit together and as stock as possible. There's enough banging going on from having the GPz seat/tank on there, and trying to stop that.
Thanks!
Thanks!
/Dave
