rusty spokes
- wireman
Re: rusty spokes
29 Jan 2014 18:37
Wax them up really good after you get the rust off of them.
- DoctoRot
Re: rusty spokes
30 Jan 2014 03:17
lacing and truing wheels really isn't that complicated it just takes patience. I actually really enjoy doing it. I have laced several wheels for friends because i like doing it. you just need to get all zen and not rush it.
- Kidkawie
- I bleed premix
Re: rusty spokes
30 Jan 2014 05:24DoctoRot wrote: lacing and truing wheels really isn't that complicated it just takes patience. I actually really enjoy doing it. I have laced several wheels for friends because i like doing it. you just need to get all zen and not rush it.
+1
You can buy some zinc spokes for about 1/2 what stainless spokes cost and they will still look good for years. Lacing isn't that big of a deal if you follow a couple guidelines. After you do one wheel you'll wonder why you didn't try it earlier.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
2004 KX125
Re: rusty spokes
30 Jan 2014 06:28 - 30 Jan 2014 06:29Can you post photos of your wheels, brake disks, speedo drive, & forks.?crusierlover wrote: Brian, here on this site, said i was stuck with the spoke wheels unless i changed front ends, forks, brakes, and all.I have another frame with forks, rotors and mag wheels I could swap over i suppose.I think it might be a 78,79.I thought i just swap the spoke wheels for the mag wheels.He said no.
I'll guess you have the 48-spokers from a 1000-CSR.
If your bike is the 81 1000-K1 Ltd, then it came stock w cast alloy wheels, so assuming the front end is stock, you should be able to convert it back to the stock wheels.
Last edit: 30 Jan 2014 06:29 by martin_csr.
- KZB2 650
Re: rusty spokes
30 Jan 2014 09:16
Maybe some 240 to 320 grit 400 final, and wd-40 too ?
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
- oldscut385
Re: rusty spokes
30 Jan 2014 09:17
i would try ebay for new spokes take a picture of your wheel so you know how the spokes are laced do that yourself then all you need is a place to true them. see i can do all that stuff myself wish i could help but try ebay for spokes ive gotten sets between like 30 and 50$
- crusierlover
Re: rusty spokes
30 Jan 2014 11:51martin_csr wrote:Can you post photos of your wheels, brake disks, speedo drive, & forks.?crusierlover wrote: Brian, here on this site, said i was stuck with the spoke wheels unless i changed front ends, forks, brakes, and all.I have another frame with forks, rotors and mag wheels I could swap over i suppose.I think it might be a 78,79.I thought i just swap the spoke wheels for the mag wheels.He said no.
I will post pictures here.I assumed the bike came with these wheels.They are are front and back, doesnt look like the bikes has been altered, but maybe it has.I might just try relacing, but the rustoff liquid will be first.
Proud owner of 1982 650csr again soon. keeping it this time
- pete greek1
Re: rusty spokes
30 Jan 2014 12:52
back in the day, I used SOS pads,,,,,but JUST on the spokes, ...DO NOT use on chrome, or painted surfaces, it was tedious work,, they looked like new when I was done, cant remember what kinda wax, or sealer I used, to keep-em looking like that, it was a cheap fix for me over 35 yrs ago ....Pete
- crusierlover
Re: rusty spokes
30 Jan 2014 18:09pete greek1 wrote: back in the day, I used SOS pads,,,,,but JUST on the spokes, ...DO NOT use on chrome, or painted surfaces, it was tedious work,, they looked like new when I was done, cant remember what kinda wax, or sealer I used, to keep-em looking like that, it was a cheap fix for me over 35 yrs ago ....Pete
Thanks pete.Looks like I got some scrubbing to do.
- Kidkawie
- I bleed premix
Re: rusty spokes
31 Jan 2014 06:31
If you want to be super lazy and cheap, just make a oxalic acid bath and soak the wheels for and hour.
1975 Z1 900
2004 KX125
2004 KX125
- z1kzonly
Re: rusty spokes
31 Jan 2014 07:55
Those rims are aluminum. D.I.D I believe.
Tighten, true all the spokes.
Then powdercoat everything silver all at once.
I know a guy that does this. Junk rims, they look great afterward.
The following user(s) said Thank You: crusierlover
