Front Caliper Rubs
  • bugsinmyteeth
  • bugsinmyteeth's Avatar Topic Author
Front Caliper Rubs
16 Jan 2014 12:39
#618857
I just replaced tires on my 1975 Z1. Took the wheels off the rims and took them to a local bike shop for mounting and balancing. I left the front axle in the wheel when it went to the shop so they had to remove it for the balancing. When I re-mounted the front wheel I noticed there is a slight scraping noise when I spin the tire. I think it is the brake disc rubbing in the caliper ever so slightly. (the bike has one front disc brake). As far as I can tell there is no adjustment for moving the wheel left or right on the axle.
Any thoughts as to what should be done?
Old School Is Cool!
1975 Kawasaki 900 (Z1B)
1982 Suzuki GS750E
Northern KY
  • sbc1320
  • sbc1320's Avatar
Re: Front Caliper Rubs
16 Jan 2014 12:54
#618859
Did you squeeze the front brake which should center up the caliper as it is a floating caliper?
1980 KZ1000 LTD-B4(MK II engine) - Progressive suspension, MTC pistons, Dynojet Stage III, all wear items replaced, WFO paint scheme(1978), etc..
Past bikes- 2 1976 Kz900's, 5 1975-76 Honda CB750's, Honda 500 -4, Honda 250, Honda 125, Honda 100, Suzuki RM 250, Honda XL350, Kawasaki KLR 650, etc..
  • wireman
  • wireman's Avatar
16 Jan 2014 13:48
#618863
Ride it around a little bit, it should stop squeeking.
The following user(s) said Thank You: bugsinmyteeth
  • bugsinmyteeth
16 Jan 2014 14:44
#618868
I was hoping it would be something like that--caliper needing to "reset" or "just ride it a bit and it will probably work its way out."
Snow and ice make riding it a bad idea for now. In fact, I had a hard time standing up in the parking lot on the way out of my office tonight. But soon as I get a chance I want to scuff in those new tires. I'll check the disc to see if its getting hot and make sure the wheel still turns freely.
Old School Is Cool!
1982 Suzuki GS750E
Northern KY
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
17 Jan 2014 06:59
#618939
the pads will typically rub enough to give a little swoosh sound,
but they shouldn't rub enough to drag or heat the disk up while riding.
  • bugsinmyteeth
17 Jan 2014 20:48
#619050
perhaps the noise is normal. don't recall it doing that before though but I wasn't looking for that either. I'll give it a ride around the block and see if the disc heats up. I'll take it easy so if it grabs I won't get in too much trouble. Snow and ice here today and more coming tomorrow.
I also was thinking about draining the brake fluid and putting new in.
Old School Is Cool!
1982 Suzuki GS750E
Northern KY
  • bountyhunter
  • bountyhunter's Avatar
17 Jan 2014 21:21
#619053
Make sure the caliper can still slide on the mounting pins, many freeze over time. Guess how I learned that....
