Brake rotors
- uglee
- New 2da game but Tru 2this thang!!!!!
Brake rotors
11 Nov 2013 18:49
Trying to do a wheel swap on my kz400 project but ran into a big problem. Front wheel bolts up but rotor is too big. Can and do you guys think a machinist is able to take an 1/8th of an inch off the rotor? The wheel is off a 2009 Ninja 250. Other than that I would have to get the front caliber off a Ninja and make a bracket to fit the factory kz400 forks. Not for a complete swap of the front-end since the wheels were free.
- bountyhunter
Re: Brake rotors
12 Nov 2013 13:30
I would think that would be pretty easy to do for a machinist.
- Beaner242
Re: Brake rotors
12 Nov 2013 13:55
Shouldn''t be a problem for any competent machine shop.
1982 KZ1000K LTD Chopper
- Cynjut
Re: Brake rotors
12 Nov 2013 14:27
I'd bet even an incompetent one could probably get the job done....
1977 KZ-1000 A1
1982 KZ-1000 M2 Frankenbike
- uglee
Re: Brake rotors
12 Nov 2013 18:00
so no safety issue with trimming brake rotors??that was my main concern since this is a wave type rotor.
- T_Dub
Re: Brake rotors
13 Nov 2013 03:41
I dont see any, as long as its cut nice and slow and he makes doubly sure the thing is centered in the lathe before starting. Cutting very slowly will be the key to not bending it or damaging it. But a competent machinist will see this.
1977 KZ650B1
-810cc
-Cavanaugh Racing Head
-Mikuni RS34's
-GPR Muffler
-810cc
-Mikuni RS34's
-GPR Muffler
- 80B4
Re: Brake rotors
13 Nov 2013 06:00
If you are going to make a bracket to mount the Ninja caliper then you don't need to machine the rotor. Just design the bracket to put the caliper in the correct position over the rotor.
1980B4 1000
1978 Z1R
1978 B3 750
1978 Z1R
1978 B3 750
The following user(s) said Thank You: PLUMMEN
- uglee
Re: Brake rotors
13 Nov 2013 11:07
not having the caliper adds to cost and making the bracket means a fabricator to design it. Simple solution on my end is to cut the rotor 1/8th of an inch then add spacers to shim the wheel to center. Looking for a decent machinist in Houston,Tx as I type.
- 80B4
Re: Brake rotors
13 Nov 2013 13:16
So, what caliper are you going to use?
1980B4 1000
1978 Z1R
1978 B3 750
1978 Z1R
1978 B3 750
- sbc1320
Re: Brake rotors
13 Nov 2013 13:2280B4 wrote: So, what caliper are you going to use?
I think the one for his bike, he is just changing wheels.
1980 KZ1000 LTD-B4(MK II engine) - Progressive suspension, MTC pistons, Dynojet Stage III, all wear items replaced, WFO paint scheme(1978), etc..
Past bikes- 2 1976 Kz900's, 5 1975-76 Honda CB750's, Honda 500 -4, Honda 250, Honda 125, Honda 100, Suzuki RM 250, Honda XL350, Kawasaki KLR 650, etc..
- Kidkawie
- I bleed premix
Re: Brake rotors
14 Nov 2013 07:04 - 14 Nov 2013 07:04
cut the caliper. (Flame Retardent- ON)
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
2004 KX125
Last edit: 14 Nov 2013 07:04 by Kidkawie.
- steell
Re: Brake rotors
14 Nov 2013 21:06Kidkawie wrote: cut the caliper. (Flame Retardent- ON)
I can't see how that would work.
Care to elaborate ?
