Respoking a wheel.
  • KZQ
  • KZQ's Avatar Topic Author
  • Administrator
  • Administrator
Respoking a wheel.
09 Oct 2013 01:12
#609324
I'm just about done with respoking a wheel. Got it running pretty true about 20 thousandths. The rim's got a kink in it at the weld, always been like that. The folks at Buchanan Spoke talk about torquing the spokes to 80 inch pounds. The problem is that they want $88 for the special torque wrench. A regular torque wrench won't do the job. Any body got a work around?
TIA
Bill
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
  • Nebr_Rex
  • Nebr_Rex's Avatar
Re: Respoking a wheel.
09 Oct 2013 02:23
#609331
Could you weld a socket to the spoke wrench?
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
  • testarossa
  • testarossa's Avatar
09 Oct 2013 06:58
#609338
I have never laced up a motorcycle wheel, but have built a few bicycle wheels. On those you couldn't get all the spokes to the same tension and have the rim run true. The closer the rim is to true in its free state, the better. What I do is lace the spokes and start tightening, then get the dish close first. Next get the rim as true as possible. Then I go around all of the spokes thumping them and listening to the tone. You can find a loose one quickly this way as it will have a very low, flat tone in contrast to the tight spokes.
Two things about this may not work for motorcycle spokes. Obviously the MC spokes are much heavier and won't ring like the long and thin spokes of a bicycle wheel. Also I suspect that there is probably a minimum tension necessary due to the higher forces of a MC spoked wheel.
Oh yeah, on the bike wheels you will often hear a lot of popping from the spokes on the first ride as the wheel gets settled in to the load. You often have to correct the truing job after the first ride.
Personally, I would probably just buy the $88 wrench so I didn't have to worry weather my wheel was properly tightened when I was getting up to highway speed. I have broken spokes on a bicycle wheel before. One spoke caused the wheel to be out of true by 1/2" and it beget the next spoke breaking. That made the wheel out by 1 1/2". Not something I want happening at 70mph.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
  • testarossa
09 Oct 2013 07:05 - 09 Oct 2013 07:07
#609339
I forgot to say that 0.020" should be fine.
Got a picture of the spoke wrench? You might be able to drill a hole in the end of the handle and use one of those fishing scales to pull the wrench. Measure the distance from the center of your drilled hole to the center of the end which fits over the spoke. 6" center to center X 13 1/3 lbs pull = 80 in lbs.
Make sure you pull at a 90 degree angle to the wrench for accuracy.
2004 ZX-10R
Angola, IN
Last edit: 09 Oct 2013 07:07 by testarossa.
  • DoctoRot
  • DoctoRot's Avatar
09 Oct 2013 08:02
#609345
When i was lacing my first set of wheels i was paranoid about doing them right so i took them to the Wheel Master and he said he never uses a torque wrench, he just does it by tapping the spokes. they should have a clear ring not a dull one. they all will have different torque values because that's how you true the rim. it was actually pretty intuitive once he showed me.
  • Kidkawie
  • Kidkawie's Avatar
  • I bleed premix
09 Oct 2013 10:38
#609351
Tap the spoke with a wrench. If it rings it's good, if it thumps it's loose. On spokes that sound loose, make sure they aren't touching a crossing spoke. You can push on the other spoke then tap it.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
  • KZQ
  • Administrator
  • Administrator
09 Oct 2013 13:38
#609366
Thanks Guys. All good information. One thing I read on the Buchanan site was that loose spoke flex and it's the flexing that causes them to break. They insist on 80 inch pounds. I think I'm gonna take Testarossa's suggestion and use a force meter (I have one) with a hole a given distance from the spoke nipple. Once I get the feel for 80 inch pounds, I'll go to just turning them that tight.
Thanks Again.
Bill
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
  • Kidkawie
  • Kidkawie's Avatar
  • I bleed premix
10 Oct 2013 10:19
#609502
In a perfect world with a perfectly round rim the 80in lb would work. Every wheel I've built, whether new or used stuff there's always a varying tension to get the wheel as true as possible. Not to mention, sometimes you get a "skip" tightening some spokes. They don't tighten smoothly like a bolt does. Greasing the threads and where the nipple sits into the rim helps with that.
1975 Z1 900
2004 KX125
The following user(s) said Thank You: BlackZ1R
