Front Tire movement / camber
- Jedsdead
31 Aug 2013 23:11
I've just put the front wheel on my 83 KZ550H. This bike sat for 10 years and was given to me with a lot of parts off, including the front wheel was off the bike. I've put it together as per the schematics, and tightened the axle nut to specified torque. The first time I put it together, I didn't line the speedometer housing properly, but figured that out (I hope).
But the wheel has a bit of play in it...probably a quarter inch or so. This can't be normal...is it?? If not, any ideas???
Thanks
Thanks
1983 KZ550H GPz
- Nebr_Rex
Re: Front Tire movement / camber
31 Aug 2013 23:21
Play in which direction?
Side to side on the axle?
Or is it tilting sideways compared to the forks?
Pics would help.
Pics would help.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- Jedsdead
31 Aug 2013 23:27
I grab the top of the tire and move it sideways....sorry I don't have a lot of experience with bikes so I'm not sure what else I can tell you...I will post pics a little later if it helps. I don't have the 'pinch bolt or screw' - so I'm not sure if that makes a difference.
Thanks
Thanks
1983 KZ550H GPz
31 Aug 2013 23:32
Not normal - don't ride it like that as is may be dangerous. Can you tell if the axle moves when you move the tire sideways or is the axle stationary and the tire/wheel twisting on the axle? Ed
The following user(s) said Thank You: Jedsdead
- Jedsdead
31 Aug 2013 23:36
looks to me like the axle is stationary but the wheel moves...I can see the hub moving while the speedometer housing stays still....and the brake disk is certainly moving against the calipers.
1983 KZ550H GPz
- Jedsdead
31 Aug 2013 23:45Attachment IMG-20130831-00054.jpg not found
Attachment IMG-20130831-00053.jpg not found
not sure if these help
1983 KZ550H GPz
The following user(s) said Thank You: crock62
- Nebr_Rex
31 Aug 2013 23:57
Bottom pic doesn't look right.
I'm think maybe bearings.
I don't have a 550 but I have 750 and 440 bikes.
And some of them have a leading axle forks also,
so they should be the same basic design.
I'll look tomorrow and compare them with your pic.
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- Jedsdead
01 Sep 2013 00:12
Thanks, I truly appreciate the help
1983 KZ550H GPz
01 Sep 2013 00:12
I think I would remove the front wheel from the bike, put the axle through the bearings, and see if there is any wobble between the axle and bearings. If there is any detectable wobble the bearings should be replaced. Ed
- Jedsdead
01 Sep 2013 00:14
The missing pinch bolt wouldn't make a difference would it. Don't have that part.
I'm going to take the axle off again and see if I'm missing something.
1983 KZ550H GPz
- Jedsdead
01 Sep 2013 00:16650ed wrote: I think I would remove the front wheel from the bike, put the axle through the bearings, and see if there is any wobble between the axle and bearings. If there is any detectable wobble the bearings should be replaced. Ed
Thanks ed...I'll do that tonight
Was really hoping to take this bike on its maiden ride this weekend.
1983 KZ550H GPz
01 Sep 2013 00:21
If the pinch bolt is missing is it possible the axle is moving up and down in the fork leg when you twist the tire? Also, I would not ride the bike with that pinch bolt out. Ed
