Front Tire movement / camber
- Jedsdead
Re: Front Tire movement / camber
01 Sep 2013 00:35
Is this a special bolt or can I substitue any bolt in there?
1983 KZ550H GPz
- Nebr_Rex
01 Sep 2013 00:59
Use a metric bolt the correct size and length with a lock washer.
A bolt that is not threaded all the way to the head would be best.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
01 Sep 2013 01:03
I would try to get a stock Kawasaki bolt fork bolt. If you cannot track one down, maybe a KZRider member can give you the exact measurements of one like it. If so, I would get a high grade replacement bolt from a place that has a really good selection of metric fasteners. Here's a description of bolt grades, notice 1/2 way down shows metric grades. Bolt Depot has a good selection, so it is one place to consider if you can't find a genuine Kawasaki bolt; just be sure you have the exact measurements before ordering. Ed
www.boltdepot.com/fastener-information/M...olt-Grade-Chart.aspx
- MDawnz1
01 Sep 2013 03:52
Hay Jedsdead,
Thats what we are trying to avoid ,
Jed being dead.
Yes you NEED the stock OR better pinch bolt.
It looks like something else is missing from the right side (the pinch bolt side) on that setup.
I don't know what it is, but too much NOT painted red and its to clean.
Maybe a dust cover of some kind?
And I hope what I see in the top photo is a piece of straw or grass or something,
stuck to the dirt on the wheel,
and not a big ass crack.
DO NOT RIDE IT THE WAY IT IS !!!!!
We do not want JED to be DEAD.
All kidding aside ,
Don't ride it without the pinch bolt.
And you cant ride it with that kind of slop in your front wheel.
Mike
Jed being dead.
All kidding aside ,
Mike
1974 Z1a, still 903
- Nebr_Rex
01 Sep 2013 04:02Jedsdead wrote:Attachment IMG-20130831-00054.jpg not found
Attachment IMG-20130831-00053.jpg not found
not sure if these help
Are you sure that wheel is mounted the right way?
There are 2 tangs on the speedo gear, and they fit into
corresponding notches in the bearing cover. Also check
for an arrow on the tire sidewall for direction of rotation.
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- Jedsdead
01 Sep 2013 04:19
LOL Mike...you are very observant...it was straw. As I mentioned, the bike sat for 10 years in a barn. The front tire was the last thing to go on and hasn't been cleaned yet.
I will order the pinch bolt.
I have looked at the pics on kawi.com and the only pieces that I have to put on are the axle, spacer, speedometer, and axle nut, unless I am missing something.
Maybe Ed was right above and the bearings are ruined...although I'm not sure I would get this kind of movement even if that was the case.
1983 KZ550H GPz
- Jedsdead
01 Sep 2013 04:22Nebr_Rex wrote:Jedsdead wrote:Attachment IMG-20130831-00054.jpg not found
tire is on correctly...I fretted over this for about an hour until I saw those arrows. I'm fairly certain I got the speedometer into the notched...but I will take it off and try to make sure.
1983 KZ550H GPz
01 Sep 2013 08:25
Perhaps the wheel bearing are missing?
- Jedsdead
01 Sep 2013 11:54
thanks Patton, but the wheel bearings are in.
Ok so I took the wheel off again. Speedometer housing looks fine. I ran the axle back through the hub, and the same shake is there. Should the axle be tight here (no play if I try to lift the axle up and down)or should there be some give.
If not, does that mean the bearings are gone?
thanks again for all the help
1983 KZ550H GPz
- Nebr_Rex
01 Sep 2013 13:03
Yes, they should be tight. I have had to tap the axle thru with a hammer before.
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
The following user(s) said Thank You: Jedsdead
- MDawnz1
01 Sep 2013 20:20
OK,,,
Nuff said,
Now you know why the bike was parked.
Sounds like bearings are PAST dead.
Still have the wheel off ?
Put the axle through it and have someone give it a slow spin while you hold both ends of the axle with your hands.
Does it feel like its full of rocks or nice and smoooooooooth ,,,,,,,
Let us know.
Mike
Nuff said,
Let us know.
Mike
1974 Z1a, still 903
- MFolks
01 Sep 2013 22:35
www.goallballs.com
sells good replacement wheel bearings. If you've never replaced bearings in a motorcycle wheel, it's not a big thing to do.
1.To remove the old bearings, you need to have the front wheel removed from the bike.
2.Get some 2" X 4"'s for the wheel to rest on.
3.See if there's snap ring/circlip holding the bearings in place on both sides; if there is, remove them.
4.Place the new bearings in a freezer for a few hours.
5.Obtain a propane torch & light it off, adjusting for a small flame.
6.Move the flame around the area where the bearings are, not staying in one place very long.
7.Using a hammer and long drift punch, work the other side's bearing out through the axle.
8.Check the place where the bearing came out, for burrs, and gouges, smooth those out before installing the new bearings.
9.heat up the bearing area again & quickly drop in the new bearings, they should go right in with no problems, if they stick. carefully hit the OUTSIDE of the bearing with a large socket, never the inside, making sure the bearing is straight and seated, as this will ruin the bearing race.
