new subframe. need help.
  • 78KZkid
  • 78KZkid's Avatar Topic Author
29 Aug 2013 19:33
#603785
I'm looking to make a new subframe on my kz650
I have an idea of what I'd like to do I just need some guidance and some good tip
1978 kz650
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
Re: new subframe. need help.
30 Aug 2013 11:42
#603914
whatcha want to know? :whistle:
were here to help. :evil:
  • 78KZkid
30 Aug 2013 13:04
#603923
I just want to know what materials
and measurements that should be made
Just a basic idea of where to start
1978 kz650
  • 531blackbanshee
  • Vendor
  • Vendor
30 Aug 2013 13:43
#603927
www.speedymetals.com/s-201-steel.aspx
is a good supplier.
so is
www.shapirosupply.com/index.php?main_pag...260&products_id=4411
the 1 inch o.d. with at least an .065 wall thickness in d.o.m.(drawn over mandrel,which means it is seamless) would be suitable for your project.
for ease of welding i would use the .083 wall stuff i linked to.
do you have a seat or tailpiece,cafe seat etc.that you plan to use?
  • slayer61
  • slayer61's Avatar
  • KZR FLAG RELAY CARRIER #62
30 Aug 2013 13:56
#603928
A sub-frame like you have pictured should be easy to duplicate, provided you have the seat pan/base to use as a pattern for the metal work.
30 Aug 2013 21:28
#604010
Am pretty sure about a frame and a swing-arm, but what's a "subframe?"
Good Fortune! :)
  • 531blackbanshee
  • Vendor
  • Vendor
03 Sep 2013 17:16
#604666
Patton wrote: Am pretty sure about a frame and a swing-arm, but what's a "subframe?"
Good Fortune! :)
the sub-frame is the part on the rear that bolts to the main frame.
that the seat and tailpiece attaches to.
kz's don't typically have a sub-frame.
you have to remove the rear portion of a kz frame and fabricate a sub-frame in order to have a sub-frame on a kz.
hth,
The following user(s) said Thank You: Patton
