Oil cooler mount
- david-b
- I am THAT guy
Oil cooler mount
15 Aug 2013 21:26
Hey all;
My oil cooler right now is being held in place from the PO with zip ties and wondering how this is actually supposed to connect. There's no place to mount this thing 2, so is there a bracket missing?
Any ideas? Thanks!
Attachment IMG_20130815_191724_542.jpg not found
Attachment IMG_20130815_191713_151.jpg not found
Any ideas? Thanks!
/Dave
2013 Chevy Sonic LT 1.4L Turbo
1982 Kawasaki KZ750-H3 LTD
1975 Monte Carlo 400sbc
- SLEEPER650
Re: Oil cooler mount
15 Aug 2013 21:31 - 15 Aug 2013 21:33
Make a small bracket to bolt it to and then bolt it to those two hole from the horn
78 650sr my baby
78 650sr waiting for rebuild
82 kz1100
82 kz1100
Last edit: 15 Aug 2013 21:33 by SLEEPER650.
- david-b
- I am THAT guy
16 Aug 2013 10:34
Will probably end up doing that. And since I don't have any horns, will make sure there's space for those when I buy some.
Thanks
Thanks
/Dave
- koolaid_kid
16 Aug 2013 11:36
See the dark rings around each of the mounting holes? There used to be a rubber isolation ring there so the cooler is not hard mounted to the frame. Since you will be fabricating a mounting bracket, you may wish to incorporate this feature into the mount.
1983 GPz 750
810 Wiseco, Kerker, K&N, DynoJet S3, Accel, Progressive, etc.
- baldy110
16 Aug 2013 12:40
The frame you have was not made for that oil cooler. It looks like you have a GPz750 engine but that is not a Gpz750 frame.
- rixtrix
- Ride on !
17 Aug 2013 23:13
My 1100 has mounts built into the frame-looks like you'll have to fabricate something but shouldn't be too difficult looking at the photos.
1982 GPz1100
- david-b
- I am THAT guy
18 Aug 2013 00:32
Really it seems easy enough to do so not too concerned about it. Just weird that there is no bracket there. Probably start working on something tomorrow. Need horns now. Found the wires going to them, all just cut and taped.
baldy: to the best of my knowledge, everything (frame/motor) is how it was originally purchased.
/Dave
- koolaid_kid
18 Aug 2013 01:14
If you can wait a couple of days, I will post the pics of my 83, which should be similar.
The cooler certainly looks like mine, perhaps the mount is as well.
1983 GPz 750
- Old Man Rock
18 Aug 2013 11:09
Couple options....
1) Tap a couple holes in the lower neck area to align with top cooler mount holes.
2) Tac weld a couple bolts on lower neck area to align with top cooler mount holes.
3) As mentioned, use side reflector holes for mounting a fabbed mounting bracket.
Earls cooler had side mounts, so fabbed side brackets & used side reflector threaded holes for securing each side to cooler.....
if it helps/provides some ideas....
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- Powerstroke_fan
18 Aug 2013 11:42
I know yours is a 750 but heres how i did my 1000.
I drilled two holes in the side plates on the frame and bent two long bolts to allign with the cooler than secured them with two nuts.
Then i drilled two holes in the front plate and made a flat bracket that bolted up to the mounting tabs on the cooler, then bolted it to the frame.
Attachment IMG_0792.JPG not found
Attachment IMG_0793.JPG not found
1977 KZ 1000 work in progress
- baldy110
18 Aug 2013 19:16Please Log in or Create an account to join the conversation.
- david-b
- I am THAT guy
18 Aug 2013 19:46
All good ideas and everything looks great. I'll play around with it (didn't have a chance to today) this week and post back my results.
Thanks!
Thanks!
/Dave
