Brake troubles continued.
- ggenovez
27 Jul 2013 00:46
Hi all,
A few weeks ago I posted about not getting a full brake lever.
It all started over a month ago, when I tried to get my bike inspected, and it failed because the brakes were dragging.
So I replaced the inner seal, and the dust boot on the front brakes and could not get them to bleed. I noticed fluid on the right side, and when I took it apart, a chunk of the seal was missing.
Replaced the seal. Still no full brakes.
I figured the rubber from the speed bleeders was gone and that could be my trouble. Tired teflon. nothing. Tried RTV, nothing. Tried new bleeder from the dealer $$$ nothing
I picked up a vacuum bleeder and ran 2 quarts through. Nothing.
I'm open to any ideas.
Any way to tell if one caliper is working more than the other? or better yet, is there a way to disable one side and see if I can get a full pedal with one brake, then try the other side to see if I can localize what caliper is causing me trouble?
Thanks
G
Thanks
G
KZ-1100 A1
Re: Brake troubles continued.
27 Jul 2013 01:31
Some clarification may help regarding which caliper was dragging, and which brake components were worked on -- master cylinder (front and/or rear)? -- which of the three calipers? -- which seal(s)? -- which dust cover(s)?
Is the master cylinder failing to pump fluid into the brake line?
- ggenovez
27 Jul 2013 11:14
Thanks Patton.
My apologies for not being clearer. The front two calipers where dragging. I replaced the piston oil seal ( 43049-002 ) and the piston dust boot ( 49006-1043).
The master was rebuilt a few months ago, and I was able to get a full pedal prior to rebuilding the calipers.
Hope that helps.
G
Hope that helps.
G
KZ-1100 A1
27 Jul 2013 14:46
Thanks.
Am understanding: new caliper seals and dust covers, with a properly functioning master cylinder.
Is the main issue at this time a lack of success in bleeding the front brakes to achieve a tight hard lever when squeezed?
Or is "brake drag" still a suspected problem?
- ggenovez
27 Jul 2013 15:14
It is the lack of success of bleeding the brakes. The best I could ever do is mild success just under where the lever touches the grip.
KZ-1100 A1
- Motor Head
27 Jul 2013 17:04
Lots of people do it in reverse. Get a syringe or another low pressure implement, and put brake fluid in through your bleeders. You need to fill it with clean brake fluid and then clear it of air, hook it to a open bleeder, slowly fill. Air will bubble up through the return port in the master, but you will also add fluid this way, so you need to be careful not to overfill the master.
The following user(s) said Thank You: kamakazie1000
- ggenovez
27 Jul 2013 17:08
Thanks Motor head. Any idea where to get a large syringe from?
KZ-1100 A1
- eddiem
- KZR FLAG RELAY CARRIER #63
27 Jul 2013 17:16
got a dairy supply business close by? they will have some
1976 Kz900
1978 Kz1000
1978 Z1r
1982 Kz1100 A2
1975 Z1b-900
1975 Z1b-900
1978 Kz1000
1978 Z1r
1982 Kz1100 A2
1975 Z1b-900
1975 Z1b-900
The following user(s) said Thank You: ggenovez
- Motor Head
27 Jul 2013 17:22Walmart, Rite-Aid, Target, etc. Basically any place like a drug store. They should have more than just the Needle hypodermic size.ggenovez wrote: Thanks Motor head. Any idea where to get a large syringe from?
27 Jul 2013 17:29
When filling the brake system with fluid, may use an inexpensive rubber ball style syringe with a short hose attached to the end which connects snugly over the bleeder nipple.
M/C reservoir is uncovered (to watch the fluid rise up inside).
Bleeder nipple is slightly loosened.
Brake hand lever isn't being squeezed.
Suck a load of fresh "unskaken" fluid into the syringe, remove from fluid and press out the air, and re-immerse and re-suck, repeat as needed until the syringe is almost full.
With the tube pointing upward, squeeze slight pressure on the syringe to expel all air (fluid is barely escaping from end of attached hose).
Holding it in this condition (no air in the syringe or hose), attach the hose onto the bleeder nipple.
Squeezing the syringe will now push fluid from the syringe through the hose and into the bleeder nipple.
Don't release squeeze pressure on the syringe while attached to the loosened bleeder nipple.
If more fluid becomes needed in the syringe, tighten the bleeder nipple before relaxing and removing the syringe.
Refill the syringe and resume the filling process as earlier described.
As fluid fills the system, it will eventually appear and rise up inside the master cylinder.
When the M/C becomes filled, tighten the bleeder, without having relaxed pressure on the syringe.
Then remove the syringe and hose.
Normal bleeding procedure should now expel remaining air from the brake system.
- kzz1king
28 Jul 2013 00:47
I found a nice sized syringe in Walmart in the oil section. It is for measuring small amounts of 2 cycle oil. It saved me a ton of work changing oil in the forks.
Wayne
Wayne
Home built KZ1000 turbo setup
