Oops...That broke it! Front Wheel problem
- steell
Re: Oops...That broke it! Front Wheel problem
03 Jul 2006 14:15
Run the fender without the arms on it. There are two bolts on each side attaching the fender to the forks, so it can't pivot. I removed the arms from the front fender on the bike in my avatar a long time ago, and that's not the first one I have done it on.
There are several others here that run without the arms as well.
Just make sure the mounting bolts are tight and the fender is not cracked in the area near the bolts.
But you have bigger problems than that
Looking at the last pic you posted the bearing looks to be fubar'd, and if that is the axle nut sitting inside the hub, where did the internal spacer go?
Post edited by: steell, at: 2006/07/03 17:21
- fixer5000
04 Jul 2006 02:19
fourtoes...i e mailed you im searching for that cover...steve
1978 kz650b pretty much stock
massachusetts
massachusetts
- biodello
04 Jul 2006 06:34
Fourtoes wrote:
For this picture, could you use that JB Weld stuff for metal? It may be worth a try. You might not be able to get the bolt out if you just attach it as is. If you use the JB Weld with the screw removed, you may need to retap, but it is probably a faster solution if you want to keep the arm on the fender.
- Fourtoes
04 Jul 2006 08:22
Thanks guys.
If I was to replace the fender for a smaller one, can I use one off any z (on the off chance it will fit). Are there any similar bikes that I can use a fender off?
Then I can just tidy up the broken bolthole.
I'll take the wheel off and check behind the hub, repair if I cant replace.
Thanks again
Thanks again
- 77KZ650
04 Jul 2006 09:48
I think most of the z1 and kz fenders swap right?...I was told an LTD fender would be a good choice for my bike. i think gpz fenders fit too., do a search in the archives to verify
07 MDP Rookie of the Year
- btchalice
04 Jul 2006 12:31
i know the 82 spectre fender is going on my 900 but i have to redrill the rear holes
Terry Meyer / Wichita KS
76 kz900 w/1000 motor TWZTD
- fixer5000
04 Jul 2006 13:12
massachusetts
massachusetts
- Fourtoes
05 Jul 2006 01:02
fixer5000, sent you a PM, not sure if you got it?
- fixer5000
05 Jul 2006 03:49
got it and your paypal payment. customs form wants a phone number for you and then its on its way today!!details details...youd think i was shipping diamonds lol steve
massachusetts
massachusetts
- Fourtoes
05 Jul 2006 04:01
Cheers steve, I've sent you a PM.
I'm now atching about a dozen different fender on good old Ebay and will keep you all posted.
Thanks for your help.
Fourtoes
Fourtoes
- fixer5000
05 Jul 2006 04:43
the cover should be on its way around 9am when the post office opens today. you know you can replace just the fender stays if your fender isnt mangled right?? you might want to try a wrecker over there for that. i do see them on e bay from time to time. i got more stuff from e bay as spares then ill ever use but you never know and this stuff isnt getting any easier to find. let me know when you get the cover just so i know it got there...steve
massachusetts
massachusetts
