Oops...That broke it! Front Wheel problem
- Fourtoes
03 Jul 2006 11:52
Pulled off on my Z650 yesterday to find my girlfriend had been helpful and chained the front wheel for me....just to be on the safe side. Clunk clunk bang bang later. And I've got a mangled hub and broken mudguard arm/fork. Spokes look ok but the wheels a little squeeky.
My question is...what damage has it likely done? Whats beneath the hub and has it probably been damaged?
Can it be easliy repaired? The hub and mudguard arm or can I ake the arms off and just leave the mudguard. Do you guys across in the States call it a mudguard or refer to it as a fender?
Post edited by: Fourtoes, at: 2006/07/03 14:56
- patmann
Re: Oops...That broke it! Front Wheel problem
03 Jul 2006 11:56
I think fender or mudguard either one works for MOST people.
From the looks of it.. I would take the wheel off, remove the hub cover, and look inside. It really doesn't look too bad. All that should be in there is your bearings PRESSED inside. The cover should just stop rain and mud from getting to it ( if I remember correct ).
Check on eBay or on here for a new/used cover if you can't straighten it. And I agree with fixing that mudgaurd ASAP !!!
Post edited by: patmann, at: 2006/07/03 15:08
1974 900 Z1 modified to look like a LTD , some engine mods. But I still have all the original parts.
1977 1000 project bike
1972 H1 project bike
If pro is opposite of con, then what is the opposite of progress?
- Fourtoes
- Fourtoes
- ambergrismooon
03 Jul 2006 12:05
I'd say fender! I wouldnt chance running with that fender without the arms. If the bottom of the fender should flex into the wheel some nasty things could happen fast. There is aome stuff here in the states called Allumalloy with which you could build another boss and drill and tap to reattach the arm. It would be a long way to go. I'd say get a shorter (stiffer) fender made to run without arms or get another fork leg. You could cut that fender down just make sure you cannot flex it into the tire! Yer back on the road before you can say "Bobs you're uncle!". Did I do that right?:whistle:
- kzmarvo
03 Jul 2006 12:15
Around these parts we call em fenders.
Watch it folks,i have sticky fingers when it comes to a nice looking set of handle bars:)
- wireman
03 Jul 2006 12:47
id just put a differant style fender that didnt need the support brackets.
- 77KZ650
03 Jul 2006 12:54
Fourtoes wrote:
Post edited by: 77KZ650, at: 2006/07/03 15:59
if you take off that cover, the wheel looks the same as the other side... a place to mount another brake disc
07 MDP Rookie of the Year
- btchalice
03 Jul 2006 13:09
if shipping isnt outrageous i have a pair of forks and a beautiful fender you could have for shipping cost
Terry Meyer / Wichita KS
76 kz900 w/1000 motor TWZTD
- Fourtoes
03 Jul 2006 13:15
Thats very good of you btchalice. I would imagine the shipping costs would be enormous but thats very kind of you to offer.
- fixer5000
03 Jul 2006 14:10
i have the cover. switched to duals this yr and i dont need it. same deal its yours for shipping cost only...steve
1978 kz650b pretty much stock
massachusetts
massachusetts
- hwms
03 Jul 2006 14:11
I would simply heliarc the piece back in and refinish.
