Oops...That broke it! Front Wheel problem
  • Fourtoes
  • Fourtoes's Avatar Topic Author
03 Jul 2006 11:52
#58961
Pulled off on my Z650 yesterday to find my girlfriend had been helpful and chained the front wheel for me....just to be on the safe side. Clunk clunk bang bang later. And I've got a mangled hub and broken mudguard arm/fork. Spokes look ok but the wheels a little squeeky.
My question is...what damage has it likely done? Whats beneath the hub and has it probably been damaged?
Can it be easliy repaired? The hub and mudguard arm or can I ake the arms off and just leave the mudguard. Do you guys across in the States call it a mudguard or refer to it as a fender?
Post edited by: Fourtoes, at: 2006/07/03 14:56
  • patmann
  • patmann's Avatar
Re: Oops...That broke it! Front Wheel problem
03 Jul 2006 11:56
#58964
I think fender or mudguard either one works for MOST people.
From the looks of it.. I would take the wheel off, remove the hub cover, and look inside. It really doesn't look too bad. All that should be in there is your bearings PRESSED inside. The cover should just stop rain and mud from getting to it ( if I remember correct ).
Check on eBay or on here for a new/used cover if you can't straighten it. And I agree with fixing that mudgaurd ASAP !!!
Post edited by: patmann, at: 2006/07/03 15:08
1974 900 Z1 modified to look like a LTD , some engine mods. But I still have all the original parts.
1977 1000 project bike
1972 H1 project bike
If pro is opposite of con, then what is the opposite of progress?
  • Fourtoes
03 Jul 2006 11:57
#58965
Heres another pic
  • Fourtoes
03 Jul 2006 11:58
#58967
And another
  • ambergrismooon
  • ambergrismooon's Avatar
03 Jul 2006 12:05
#58971
I'd say fender! I wouldnt chance running with that fender without the arms. If the bottom of the fender should flex into the wheel some nasty things could happen fast. There is aome stuff here in the states called Allumalloy with which you could build another boss and drill and tap to reattach the arm. It would be a long way to go. I'd say get a shorter (stiffer) fender made to run without arms or get another fork leg. You could cut that fender down just make sure you cannot flex it into the tire! Yer back on the road before you can say "Bobs you're uncle!". Did I do that right?:whistle:
  • kzmarvo
  • kzmarvo's Avatar
03 Jul 2006 12:15
#58978
Around these parts we call em fenders.:P
Watch it folks,i have sticky fingers when it comes to a nice looking set of handle bars:)
  • wireman
  • wireman's Avatar
03 Jul 2006 12:47
#58994
id just put a differant style fender that didnt need the support brackets.;)
  • 77KZ650
  • 77KZ650's Avatar
03 Jul 2006 12:54
#58997
Fourtoes wrote:
Heres another pic
if you take off that cover, the wheel looks the same as the other side... a place to mount another brake disc
Post edited by: 77KZ650, at: 2006/07/03 15:59
07 MDP Rookie of the Year
  • btchalice
  • btchalice's Avatar
03 Jul 2006 13:09
#58999
if shipping isnt outrageous i have a pair of forks and a beautiful fender you could have for shipping cost
Terry Meyer / Wichita KS
76 kz900 w/1000 motor TWZTD
  • Fourtoes
03 Jul 2006 13:15
#59002
Thats very good of you btchalice. I would imagine the shipping costs would be enormous but thats very kind of you to offer.
  • fixer5000
  • fixer5000's Avatar
03 Jul 2006 14:10
#59017
i have the cover. switched to duals this yr and i dont need it. same deal its yours for shipping cost only...steve
1978 kz650b pretty much stock
massachusetts
  • hwms
  • hwms's Avatar
03 Jul 2006 14:11
#59018
I would simply heliarc the piece back in and refinish.
