Suzuki 900 swing arm swap to Z1
  • turboking
  • turboking's Avatar Topic Author
20 May 2013 13:53
#588354
I dug out the rf900 swingarm and wheel assembly that I'm going to use , here are 2 pix..... :huh: I'm planing on using the brake and shifter :pinch: unless I find something better
[IMG
[IMG
2005 Kawasaki mean streak
1979 kz 1000 mk II ATP turbo
1975 Z1 960 cc Mr. Turbo
1976 Kz900 1103 cc ATP turbo
1985 GS 1150E
1983 GS 1100E
1997 Suzuki Bandit 1200S
2001 Kawasaki EX 500 Ninja
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
Re: Suzuki 900 swing arm swap to Z1
20 May 2013 16:37
#588383
sir,
we will need alot of pictures as you document this swap :P.
  • 650mod
  • 650mod's Avatar
20 May 2013 17:31
#588393
531blackbanshee wrote: sir,
+1 with Leon here.
78 kz 650 custom
Wiseco 720cc big bore
Dynajet stage 3 carb kit with pods
2002 Kawasaki Z750 exhaust
2001 Buell lightning front end
1999 Ninja 600 swingarm with 1999 Ninja 900 rear rim
converted to monoshock rear
Too many goodies to list fully
  • turboking
20 May 2013 17:35
#588394
I plan on doing just that...... ;)
1985 GS 1150E
1983 GS 1100E
  • 531blackbanshee
  • Vendor
  • Vendor
21 May 2013 09:44
#588490
thatsa good lil kzrider :silly: !
  • turboking
21 May 2013 18:04
#588580
plan is to use the RF 900 mono shock mounts as it had a steel frame ....should make things a bit easier :pinch:
[IMG
I'm gonna slice and dice the old frame shock mounts........ :ohmy:
1985 GS 1150E
1983 GS 1100E
