Best way to remove bottom race from lower triple??
  • ramtough_63
  • ramtough_63's Avatar Topic Author
25 Apr 2013 19:33
#584019
what is the easiest way to remove the bottom bearing (race?) from the lower
triple tree??
bought a set of all balls bearings replaced the races in the frame with no ptoblems
was gonna wait for my front end but I am running out of time for the blessing
and gonna throw the old forks back on to make the blessing and order another set of
bearings for the new front end any help appreciated
my new job has limited my time on projects and I get a little lazy lol
Attachment 100_7627.JPG not found
1978 KZ1000 A2
Facebook Page
Free Range Custom Art
1982/83 750R/GPZ
1984 Goldwing 1200 Interstate
1982 Yamahopper QT50
Previous
2 79 HD sporty XLH
02 HD FLSTS Heritage
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
  • bluej58
  • bluej58's Avatar
Re: Best way to remove bottom race from lower triple??
25 Apr 2013 19:43 - 25 Apr 2013 19:45
#584020
I seem to remember cutting mine off with a Dremel type tool and a cut off wheel,
but that was about thirty years ago :lol:
78 KZ1000 A2A
Last edit: 25 Apr 2013 19:45 by bluej58.
  • ramtough_63
25 Apr 2013 19:56
#584022
I was thinking that but really didnt want to have to go to that extreme lol
thanks man appreciate it
1978 KZ1000 A2
Facebook Page
1982/83 750R/GPZ
Previous
2 79 HD sporty XLH
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
  • donthaveakawman
  • donthaveakawman's Avatar
25 Apr 2013 20:21 - 25 Apr 2013 20:22
#584024
ramtough_63 wrote: what is the easiest way to remove the bottom bearing (race?) from the lower
triple tree??
maybe that lower bearing holder will pop up with a screwdriver and who knows it may be threaded in there. is there a way to use a press?
Last edit: 25 Apr 2013 20:22 by donthaveakawman.
  • OnkelB
  • OnkelB's Avatar
25 Apr 2013 20:34
#584026
When I did mine I stuck the stem in a vise and (carefully) worked around the race with a chisel - if I remember correctly the stem is slightly fatter at the bottom where the race sits, once the race is free of that part it should come right off.
77 KZ 650 B1, 82 GPz 1100 B2.
  • ramtough_63
25 Apr 2013 20:45
#584028
used the dremel cut it off worked ok
1978 KZ1000 A2
Facebook Page
1982/83 750R/GPZ
Previous
2 79 HD sporty XLH
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
  • boatdrinks
  • boatdrinks's Avatar
25 Apr 2013 22:45
#584041
OnkelB wrote: When I did mine I stuck the stem in a vise and (carefully) worked around the race with a chisel - if I remember correctly the stem is slightly fatter at the bottom where the race sits, once the race is free of that part it should come right off.
+1 on this technique. Works fine for every one I have done.
Charles
Madison, AL
1978 KZ650 B2A, Luminous Dark Blue
  • wireman
  • wireman's Avatar
26 Apr 2013 00:31
#584049
I was going to say 4 1/2" grinder with cut off wheel,but as the old saying goes"run what ya brung"! :laugh:
26 Apr 2013 10:05
#584076
No eBay APP ID and/or Cert ID defined in Kunena configurationNo eBay APP ID and/or Cert ID defined in Kunena configurationBest way? Probably using the tool in the 1st pic below; I'm sure that's what Bill Gates or Warren Buffet would use. :laugh: :laugh: :laugh:
When I did mine I carefully cut part way through mine using a Dremel cut-off wheel then snapped it off the rest of the way with a chisel. Looking at the official tool makes me think a person could make one similar to it using a couple pieces form car muffler clamps and 2 bolts (see second pic). You might try that to see if it has potential if you have a couple old muffler clamps handy. Ed
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
26 Apr 2013 10:19
#584079
650ed wrote: Best way? Probably using the tool in the 1st pic below; I'm sure that's what Bill Gates or Warren Buffet would use. :laugh: :laugh: :laugh:
Actually...I just purchased the correct tool for this job (57001-135) as it is still available from Kawasaki...pricey, but I am a firm believer in the correct tool.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
26 Apr 2013 10:31 - 26 Apr 2013 10:32
#584083
Just out of curiosity, does it look similar to the Kawasaki Part #57001-1675 in the first picture? Thanks, Ed
Last edit: 26 Apr 2013 10:32 by 650ed.
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
26 Apr 2013 10:58
#584087
Yes...sort of...at least the bottom part of the tool I purchased resembles '1675'
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
