Shaft to Chain parts compatibility
- K.D. HART
06 Apr 2013 12:56
I seen a bike someone is stripping down on craigslist and I thought about getting some extra parts.
Will the rear rim from a 1980 KZ1000 "shaft drive" work on my "chain drive" 1978 LTD1000?
He has the motor also. Are the cases different from my engine?
kzrider.com/forum/11-projects/594694-dir...to-kz1000-now#638488
kzrider.com/forum/11-projects/591120-i-f...rbo-drag-bike#606286
kzrider.com/forum/11-projects/589806-197...750-suspension-build
- stevie g
Re: Shaft to Chain parts compatibility
06 Apr 2013 13:07
The rim off a shaft drive will not work on a chain drive. With the engine you can convert it to chain but you need quite a lot of bits to do it, inner and outer sprocket covers, gearchange shaft, gearbox lay shaft to name just a few. $
stephen g mackay
- K.D. HART
06 Apr 2013 13:28
Thanks for the info.
