Z1 Frame Repair
  • Vranasaurus
  • Vranasaurus's Avatar Topic Author
Z1 Frame Repair
01 Apr 2013 16:26
#579978
I could kick myself right now. I got my z1B frame back from the powder coater and was starting to put things back together when I suddenly realized that one of the mounting tangs for the center stand was broken off.
Anyone know of someone who does or has fabricated that piece?
Or is it time to go to the bike salvage yard and see if they have a junk frame?
1984 ZN1100
1975 Z1B
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
Re: Z1 Frame Repair
01 Apr 2013 17:28
#579986
you might check with wireman and see if he can cut you one off the frame he just cut the top off of.
  • Kidkawie
  • Kidkawie's Avatar
  • I bleed premix
Re: Z1 Frame Repair
01 Apr 2013 17:44
#579987
Make a cardboard template from one of the other tabs, cut it out of steel and weld it on. If you pc'd the frame black just hit that repair area with paint.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
  • wireman
  • wireman's Avatar
Re: Z1 Frame Repair
01 Apr 2013 21:19
#580026
If its the same dimensionally as kz frame Ive got one I can cut off for ya. :)
  • Vranasaurus
Re: Z1 Frame Repair
01 Apr 2013 22:58
#580067
I got some 1/4" steel and fabbed me a piece. I still have some more filing to do to get it to fit and then find someone to weld it. Luckily once it is painted and the bike assembled I doubt anyone will notice.
What year KZ? If I can't get this piece to work right I will let you know.
1984 ZN1100
1975 Z1B
  • wireman
  • wireman's Avatar
Re: Z1 Frame Repair
02 Apr 2013 00:12
#580102
Ive got several laying around.A 78 ltd frame that is donating its engine cradle for a future pro gas project,rest of it will be built from 4130 once I finish building a frame jig.
One of these days Ill get to that project! :sick: :woohoo:
  • Vranasaurus
Re: Z1 Frame Repair
05 Apr 2013 03:00 - 05 Apr 2013 03:03
#580649
Fixed!
1984 ZN1100
1975 Z1B
Last edit: 05 Apr 2013 03:03 by Vranasaurus.
