lowering bike.
  • bromz
  • bromz's Avatar Topic Author
  • 1981 kz1000 csr
lowering bike.
25 Mar 2013 14:09
#578706
How easy is it to lower my bike. I have a 81 csr 10000 and i think an inch or more would make it more comfy to ride cause i am at a height where i can barely sit flat footed.
  • ramtough_63
  • ramtough_63's Avatar
Re: lowering bike.
25 Mar 2013 14:19
#578707
When I first got mine I put 12.5" shocks on the rear and pushed the forks up about an inch through
the trees helped allot i only have a 28" inseam so i'm a little vertically challenged also LOL
1978 KZ1000 A2
Facebook Page
Free Range Custom Art
1982/83 750R/GPZ
1984 Goldwing 1200 Interstate
1982 Yamahopper QT50
Previous
2 79 HD sporty XLH
02 HD FLSTS Heritage
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
  • kawasaki mike
  • kawasaki mike's Avatar
  • kawasaki mike
Re: lowering bike.
25 Mar 2013 15:54
#578714
Attachment lastentry096.JPG not found
Attachment lastentry095.JPG not found
That works. I put 11 in. shocks on mine to make the swing arm level and put custom trees raked 4 degrees plus a leading axle set of forks from a 1981 csr 1000. Works great but the only pipe I can run is the marving 4 into 1 for ground and cornering clearance. Like the feel, ride, and look
Am addicted to Z1's and kz 900's have an el camino, fly rc helicoptors and am strung out on horsepower.
  • bromz
  • 1981 kz1000 csr
Re: lowering bike.
25 Mar 2013 21:05
#578755
My bike is in storage. Does anyone know what the stock rear shocks are eye to eye?
  • ramtough_63
Re: lowering bike.
25 Mar 2013 21:09
#578757
i'm thinkin 14" I'm sure different models will vary
1978 KZ1000 A2
Facebook Page
1982/83 750R/GPZ
Previous
2 79 HD sporty XLH
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
  • dbc92s10
  • dbc92s10's Avatar
Re: lowering bike.
25 Mar 2013 21:36
#578760
13.5 0n the 81 ltd and csr 1000
81 ltd1000
1135 mtc 10.5/1
cavanaugh racing head
38.6/32 p&p
APE k410 cams
APE hardware and tensioner
84 gpz1100 trans
kerker w comp baffle
rs36 carbs
fast by gast race crank
  • bromz
  • 1981 kz1000 csr
Re: lowering bike.
25 Mar 2013 21:40
#578763
Thanks guys. I will look at shorter shocks for the back and how far do you think I can push my forks thru the trees? i should lower front and back the same amount.
  • dbc92s10
  • dbc92s10's Avatar
Re: lowering bike.
25 Mar 2013 21:46
#578766
yes lower them the same
81 ltd1000
1135 mtc 10.5/1
38.6/32 p&p
APE k410 cams
84 gpz1100 trans
rs36 carbs
  • donthaveakawman
  • donthaveakawman's Avatar
Re: lowering bike.
25 Mar 2013 22:15
#578770
Is there an air filler on the forks? adjuster on the rear?
  • racer54
  • racer54's Avatar
Re: lowering bike.
26 Mar 2013 00:23
#578798
Where did you guys find and/or buy your shorter shocks?
  • mike0537
  • mike0537's Avatar
Re: lowering bike.
26 Mar 2013 03:14
#578819
Didn't I just see your bike on Craigslist in St George???
1980 KZ750E
  • z1kzonly
  • z1kzonly's Avatar
Re: lowering bike.
26 Mar 2013 11:10
#578865
Rendering Error in layout Message/Item: Kunena\Forum\Libraries\BBCode\KunenaBBCodeLibrary::renderEbayLayout(): Argument #1 ($ItemID) must be of type int, string given, called in /home/kzride5/public_html/libraries/kunena/src/BBCode/KunenaBBCode.php on line 314. Please enable debug mode for more information.
