Check out these brakes
- mark1122
- Keep twisting it
28 Jun 2006 05:48
Does anyone know what these brakes are off? They were on it when i bought it 25 years ago.Now I'm resserecting it .I ran it around the block yesterday and thought I had to pull the lever fairly hard to stop fast.Is this normal for kz's,or could i have a problem? I'd like them to be more sensitive. Would a differant master with a bigger piston help?
[img size=500]
Post edited by: mark1122, at: 2006/06/28 08:52
Post edited by: mark1122, at: 2006/06/28 08:53
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- wireman
Re: Check out these brakes
28 Jun 2006 05:52
what brakes?:whistle:
now i see it,thats a 1/2"mastercylinder normally used for single rotor it will work with dual discs you just need to pull a little harder,did you try flushing and bleeding brakes again might be more trash in there after all these years.
Post edited by: wireman, at: 2006/06/28 08:55
- mark1122
- Keep twisting it
28 Jun 2006 05:55
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- wireman
28 Jun 2006 05:58
i rember those brakes 76-77 frontend with 76-80 rotors im still drawing blank on calipers though.:S longer brake lever would probably help too.
- mark1122
- Keep twisting it
28 Jun 2006 06:27
I'm sure your right on the longer lever but I like to use 2 fingers on the brake and would like more stopping power. How sensitive are yours ? can you stop her fast with an easy two fingers or do you have to pull hard on the reins?
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- lifeliberty
28 Jun 2006 07:23
when is the last time the brake fluid was changed/bled and are those the original brake lines?
- steell
28 Jun 2006 08:24
Assuming brales are in good condition:
Larger (5/8") master cylinder means harder lever pull but shorter lever travel.
Smaller (1/2") master cylinder means less lever pull but longer lever travel.
I agree with Wireman that that is a 1/2" single disk master cylinder, and that means that with it on a two disk sytem, it should require little force for a rapid stop.
Many people with the same setup have complained about the brakes being to "sensitive", so it seems like you have a problem somewhere.
Might want to consider replacing the rubber lines and rebuilding the calipers.
- Z1R rider
28 Jun 2006 15:39
I agree with Mark, I always thought my Z1R had good brakes till I rode the kids' bikes, a GSXR-1000 and a CBR900RR. After running off the track because of a lack of braking power, I grafted on a set of ZX-6 calipers, 12 pistons total (though each is slightly smaller than the stockers) and they work great with the stock master cyl. and cable setup. Now I get that two finger lockup (or stoppie with better tires) I'm using HH pads on stock discs.
[img size=150]IMG]http://i16.photobucket.com/albums/b42/rogerstu/DSCF0001.jpg[/img]
Post edited by: Z1R rider, at: 2006/06/28 18:40
1978 KZ1000, Z1R
1999 250 Ninja race bike
- OneShoe50
- 10-4? 10-4!
28 Jun 2006 15:59
I just finished converting to dual disc on my `77 KZ1000 and I kept the 1/2" single master cylinder on the recommendation of the salvage yard I got the rotors and caliper from.
I've noticed the lever pull is kinda soft but it really stops nice without a lot of effort. And if you really jab the lever it will really nose over.
Like the other recommemdations on this thread I did clean and flush the system and used DOT 4 fluid.
77 KZ1000A1 - Under going a psuedo ELR overhaul
79 KE175 (gone)
81 KZ550A2 (gone)
81 KZ750E (gone)
Sure it looks OK now, but wait until I really make it pretty, with some chrome and paint and some new tires and grips and the wiring. Don't forget the gearing, and the LED's and, and, and....
79 KE175 (gone)
81 KZ550A2 (gone)
81 KZ750E (gone)
- mark1122
- Keep twisting it
28 Jun 2006 18:28
I have not changed the lines or blead the system.I gess thats next.Is dot 5 better than dot4?Will I notice any diff. with braided lines?Z1 those brake look great!
Post edited by: mark1122, at: 2006/06/29 02:00
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- Z1R rider
- steell
29 Jun 2006 21:59
Six pistons on each caliper, yeah I bet it does stop in a hurry!!
Looks like you got the picture posting down pat now, so I whacked the extra posts
