Check out these brakes
  • mark1122
  • mark1122's Avatar Topic Author
  • Keep twisting it
28 Jun 2006 05:48
#57688
Does anyone know what these brakes are off? They were on it when i bought it 25 years ago.Now I'm resserecting it .I ran it around the block yesterday and thought I had to pull the lever fairly hard to stop fast.Is this normal for kz's,or could i have a problem? I'd like them to be more sensitive. Would a differant master with a bigger piston help? [img size=500]
Post edited by: mark1122, at: 2006/06/28 08:52
Post edited by: mark1122, at: 2006/06/28 08:53
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • wireman
  • wireman's Avatar
Re: Check out these brakes
28 Jun 2006 05:52
#57692
what brakes?:whistle: :P now i see it,thats a 1/2"mastercylinder normally used for single rotor it will work with dual discs you just need to pull a little harder,did you try flushing and bleeding brakes again might be more trash in there after all these years.;)
Post edited by: wireman, at: 2006/06/28 08:55
  • mark1122
  • Keep twisting it
28 Jun 2006 05:55
#57694
Sorry I'm a newbee
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • wireman
  • wireman's Avatar
28 Jun 2006 05:58
#57695
i rember those brakes 76-77 frontend with 76-80 rotors im still drawing blank on calipers though.:S longer brake lever would probably help too.:P
  • mark1122
  • Keep twisting it
28 Jun 2006 06:27
#57704
I'm sure your right on the longer lever but I like to use 2 fingers on the brake and would like more stopping power. How sensitive are yours ? can you stop her fast with an easy two fingers or do you have to pull hard on the reins?
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • lifeliberty
  • lifeliberty's Avatar
28 Jun 2006 07:23
#57712
when is the last time the brake fluid was changed/bled and are those the original brake lines?
  • steell
  • steell's Avatar
28 Jun 2006 08:24
#57728
Assuming brales are in good condition:
Larger (5/8") master cylinder means harder lever pull but shorter lever travel.
Smaller (1/2") master cylinder means less lever pull but longer lever travel.
I agree with Wireman that that is a 1/2" single disk master cylinder, and that means that with it on a two disk sytem, it should require little force for a rapid stop.
Many people with the same setup have complained about the brakes being to "sensitive", so it seems like you have a problem somewhere.
Might want to consider replacing the rubber lines and rebuilding the calipers.
  • Z1R rider
  • Z1R rider's Avatar
28 Jun 2006 15:39
#57831
I agree with Mark, I always thought my Z1R had good brakes till I rode the kids' bikes, a GSXR-1000 and a CBR900RR. After running off the track because of a lack of braking power, I grafted on a set of ZX-6 calipers, 12 pistons total (though each is slightly smaller than the stockers) and they work great with the stock master cyl. and cable setup. Now I get that two finger lockup (or stoppie with better tires) I'm using HH pads on stock discs.
[img size=150]IMG]http://i16.photobucket.com/albums/b42/rogerstu/DSCF0001.jpg[/img]
Post edited by: Z1R rider, at: 2006/06/28 18:40
1978 KZ1000, Z1R
1999 250 Ninja race bike
  • OneShoe50
  • OneShoe50's Avatar
  • 10-4? 10-4!
28 Jun 2006 15:59
#57839
I just finished converting to dual disc on my `77 KZ1000 and I kept the 1/2" single master cylinder on the recommendation of the salvage yard I got the rotors and caliper from.
I've noticed the lever pull is kinda soft but it really stops nice without a lot of effort. And if you really jab the lever it will really nose over.
Like the other recommemdations on this thread I did clean and flush the system and used DOT 4 fluid.
77 KZ1000A1 - Under going a psuedo ELR overhaul
79 KE175 (gone)
81 KZ550A2 (gone)
81 KZ750E (gone)
Sure it looks OK now, but wait until I really make it pretty, with some chrome and paint and some new tires and grips and the wiring. Don't forget the gearing, and the LED's and, and, and....
  • mark1122
  • Keep twisting it
28 Jun 2006 18:28
#57898
I have not changed the lines or blead the system.I gess thats next.Is dot 5 better than dot4?Will I notice any diff. with braided lines?Z1 those brake look great!
Post edited by: mark1122, at: 2006/06/29 02:00
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • Z1R rider
29 Jun 2006 21:12
#58187
I'll get it yet!!!
1978 KZ1000, Z1R
  • steell
  • steell's Avatar
29 Jun 2006 21:59
#58197
Six pistons on each caliper, yeah I bet it does stop in a hurry!! :)
Looks like you got the picture posting down pat now, so I whacked the extra posts :)
