Master Cylinder
  • slayer61
  • slayer61's Avatar
  • KZR FLAG RELAY CARRIER #62
Re: Master Cylinder
07 Mar 2013 17:55 - 07 Mar 2013 17:59
#575829
I've had great success "reverse bleeding" my brakes.
1). empty the master cylinder.
2). fill a 20 ml syringe with brake fluid.
3). open bleed nipple.
4). connect syringe to bleed nipple with plastic hose/tube.
5). SLOWLY inject brake fluid into system until fluid appears in master cylinder.
6). close bleed nipple
7). top up master cylinder
8). squeeze brakes a few times.
9). go riding! :woohoo:
Last edit: 07 Mar 2013 17:59 by slayer61. Reason: forgot a step. sorry
  • wireman
  • wireman's Avatar
Re: Master Cylinder
07 Mar 2013 18:13
#575834
bromz wrote: do i need to open my resivoir when i do that?
Nope,just pump lever a few times and wrap zip tie around it and bar.
You might try cracking a bleeder valve in first thing in morning with lever still pulled in to see if a big air bubble comes out. B)
Re: Master Cylinder
07 Mar 2013 20:09 - 07 Mar 2013 20:15
#575859
wireman wrote: Ive used the small master cylinder with dual discs on many bikes with no troubles,Id try zip tying lever towards the bar to keep pressure on it over night to see if it works any air back up to the master cylinder B)
Retaining the 14mm master cylinder used with a single front disc, and adding a second front disc, will typically increase the sensitivity of the brake, whereby the former squeeze effort with single disc will produce a significantly increased braking action with dual discs.
Such increased lever sensitivity may be all right where the rider has become acclimated to it. But there are reports of riders being surprised by the increased braking response, such as front wheel lock-up (especially in reduced traction situations, such as wet road, damp leaves, sand, gravel, etc.), causing loss of control and tip-over.
Kawasaki had reasons for using a larger bore master cylinder with introduction of dual front discs, and it wasn't solely related to providing additional fluid for the second caliper.
A super-sensitive front brake could pose a risk to a novice rider who in a tight situation instinctively grabs and squeezes the brake lever with all his might.
Good Fortune! :)
Last edit: 07 Mar 2013 20:15 by Patton.
  • dbc92s10
  • dbc92s10's Avatar
Re: Master Cylinder
07 Mar 2013 21:33
#575883
i have the stock front master cylinder w lever off my 81 ltd1000 if you want it pm me and i will send it to you
81 ltd1000
1135 mtc 10.5/1
cavanaugh racing head
38.6/32 p&p
APE k410 cams
APE hardware and tensioner
84 gpz1100 trans
kerker w comp baffle
rs36 carbs
fast by gast race crank
  • wireman
  • wireman's Avatar
Re: Master Cylinder
07 Mar 2013 22:57
#575909
Good Fortune! :)
Chicken! :woohoo:
