Master Cylinder
- bromz
- 1981 kz1000 csr
Master Cylinder
06 Mar 2013 12:38
I put a new master on my front brakes and rebuilt the calipers and new braided lines and I still have a soft lever. Could the bore on the new master be to small. The bore is 14mm im not sure what the original bore is.
- 4TheKZ1000
Re: Master Cylinder
06 Mar 2013 13:01
Kz bikes just have soft feel on lever....not like the newer bikes.
Re: Master Cylinder
06 Mar 2013 13:07
Does your bike have dual front disks? Mine does and the bore is 5/8" or 15.875mm. I believe that is the standard size bore for KZ bikes with dual front disks. Ed
- z1kzonly
Re: Master Cylinder
06 Mar 2013 13:58bromz wrote: I put a new master on my front brakes and rebuilt the calipers and new braided lines and I still have a soft lever. Could the bore on the new master be to small. The bore is 14mm im not sure what the original bore is.
Yes, 14mm bore is for single disc.
Using it with dual, you will get the spongy feel.
Re: Master Cylinder
06 Mar 2013 14:31 - 07 Mar 2013 00:28Imo the soft lever likely results from residual tiny air bubbles within the fluid inside the brake line. Such bubbles are sometimes difficult to excise via standard bleeding. Often, the softness will dissipate and self-correct during continued usage.bromz wrote: I put a new master on my front brakes and rebuilt the calipers and new braided lines and I still have a soft lever. Could the bore on the new master be to small. The bore is 14mm im not sure what the original bore is.
Last edit: 07 Mar 2013 00:28 by Patton.
- bromz
- 1981 kz1000 csr
Re: Master Cylinder
06 Mar 2013 18:58
Yes I have dual front disk. when I squeeze my lever I can see the calipers actually squeeze on the rotors. Just didnt know if my barakes should get rock hard. I have bleed and bleed and bleed. Got rid of the splittier and went with two lines all the way down to calipers with double banjo at the master. I even reversed bleed with a syringe. just want to make sure everythink is ok. I can live with the soft brakes if thats all i get with my bike.
Re: Master Cylinder
06 Mar 2013 19:10 - 06 Mar 2013 19:11
I think you would find the brakes much better if you installed the correct size master cylinder. My brakes are not soft.
Last edit: 06 Mar 2013 19:11 by 650ed.
- bromz
- 1981 kz1000 csr
Re: Master Cylinder
06 Mar 2013 21:36
I have the original master cylinder but he sight glass is busted out of It and it will need a rebuild. I would have no idea on how to replace the glass correctly
- bluej58
Re: Master Cylinder
07 Mar 2013 08:58
At the bottom of the reservoir there is a false bottom, I guess you can call it ,that you can pop out and there is two screws underneath that come out to take off the "sight glass ".
You might want to post that you are looking for that piece in the wanted section in the forum, maybe someone can help you out .
JD
JD
78 KZ1000 A2A
- pete greek1
Re: Master Cylinder
07 Mar 2013 14:09
No eBay APP ID and/or Cert ID defined in Kunena configurationI've heard people using 14mm master cylinders with no issues, if bled right, new pads, & rotors up to specs,....
- wireman
Re: Master Cylinder
07 Mar 2013 16:53
Ive used the small master cylinder with dual discs on many bikes with no troubles,Id try zip tying lever towards the bar to keep pressure on it over night to see if it works any air back up to the master cylinder
- bromz
- 1981 kz1000 csr
