Want feedback on an idea...
- daveo
03 Feb 2013 14:45 - 16 Mar 2013 05:20
I've got a simple method to suspend the front end (wheel/tire) off the ground, for extended bike storage, and cleaning.
I wonder if this is a good idea, and can think of no-better place to find out...
Is it acceptable for me to seek opinion here?
Took awhile to figure out the pic thing
1982 KZ1100-A2/1170 sleeper 😀
Last edit: 16 Mar 2013 05:20 by daveo.
- wireman
Re: Want feedback on an idea...
03 Feb 2013 15:18Attachment skeleton-computer.jpg not found
Could you be a little more specific? :laugh:
- Lorcan
- Speed Loony
03 Feb 2013 15:31
You'll get more than opinion if you post it here... :woohoo:
760cc - 8.69@162mph
810cc, 211mph www.750turbo.com
www.stormdragbike.com
The following user(s) said Thank You: wireman, daveo
- daveo
03 Feb 2013 15:58 - 03 Feb 2013 17:12
Ok.
Well, this one is made of wood and is more or less a prototype, which I've been using for a few years. A definite go-to when washing the bike down, if I can remember where it was left after the last use, but always seem to find it where I would never have left it...
The thing is used in conjunction with the center-stand, on a flat and level floor surface. Once the bike is on the (locked) center-stand, this thing takes less than ten seconds to put in place. Without a center-stand, this thing would be useless.
It is a prop that fits under the horizontal frame cross-member, located behind the exhaust down-pipes in front of the engine.
I had to modify the design to work with the V&H system installed last year, so it works with either the factory 4-2 original, or an after-market 4-1 header.
When in place, both wheels are suspended about 3/4" off the floor, and spin freely. The front-end is able to rotate fully left to right. The wheel, and forks can be removed for servicing. I used it to support the bike while changing out the steering-head bearings too.
This unit will work with an 82' KZ1100A model for sure, and likely the KZ1000J, KZ1100 Spectre, GPZ1100, and what-all else I don't know...
Last edit: 03 Feb 2013 17:12 by daveo. Reason: add
- trianglelaguna
03 Feb 2013 18:09
opinion,
as follows
will post
stay tuned
wait
hold on a sec
you
can
as follows
will post
stay tuned
wait
hold on a sec
you
can
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
2003 ZX12R
2007 FZ1000
- daveo
03 Feb 2013 20:34 - 15 Mar 2013 21:38
Last edit: 15 Mar 2013 21:38 by daveo.
- daveo
15 Mar 2013 21:45
Finally got the pics, and sorry for the delay.
- wireman
15 Mar 2013 22:40
Yeah that looks like it would work to take load off tires and suspension
15 Mar 2013 22:57
Here's my opinion - that is one really nice clean bike with or without the stand. Ed
- trianglelaguna
15 Mar 2013 23:03
killer bike
1976 KZ900
2003 ZX12R
2007 FZ1000
2003 ZX12R
2007 FZ1000
- trianglelaguna
15 Mar 2013 23:28
so it works...if it works it works...what is the feedback you want
1976 KZ900
2003 ZX12R
2007 FZ1000
2003 ZX12R
2007 FZ1000
- donthaveakawman
16 Mar 2013 00:10
what about jack stands under the "case saver" crash bar.
