Want feedback on an idea...
  • daveo
  • daveo's Avatar Topic Author
  • Premium Member
  • Premium Member
Re: Want feedback on an idea...
16 Mar 2013 05:14 - 16 Mar 2013 11:19
#577170
trianglelaguna, and whomever else...
Marketable?
Once the bike is placed on the center stand, the prop slips under the frame cross-member while the front of the bike is easily lifted with the other hand. Since the bike is somewhat balanced on the (locked) center stand, it is easy to lift by the front wheel. And the forward weight is just heavy enough to balance the bike on the prop, resulting in a secure enough structure to remove the front wheel, forks, triple-tree, etc. for service, as well as ease of washing the front wheel by spinning it.
Whew... :)
The factory-stock center stand is mandatory for this thing to work. Without it...forget it.
1982 KZ1100-A2/1170 sleeper 😀
Last edit: 16 Mar 2013 11:19 by daveo. Reason: add text
16 Mar 2013 08:33
#577177
Some other options --
kzrider.com/forum/5-chassis/236039-center-stand
Good Fortune! :)
The following user(s) said Thank You: daveo, bluezbike
  • peter1958
  • peter1958's Avatar
  • toad
  • toad's Avatar
16 Mar 2013 08:51
#577179
I was using stands too for a while but a couple years ago I took a 6x6x10'and spanned it across my trusses in my attic above my garage, had a winch kicking around,quite easy to do, a couple hours and no more headaches or bike falling over..well worth it,chain falls are nice too.
78 kz 1000
wiesco 1015
29mm smoothbores
gs1100 swingarm
gsxr rear
  • Kidkawie
  • Kidkawie's Avatar
  • I bleed premix
16 Mar 2013 09:05
#577180
I put the exact amount of weight in the tail so the bike becomes balanced on the stand.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
  • Roadflyer
  • Roadflyer's Avatar
16 Mar 2013 12:06
#577193
Nice clean bike!
I like the spokeless front wheel in pic 2 and 3 :woohoo:
1979 kz1000 shaftie rebuild project
1045 wiseco 10.25-1 pistons
Kenny Harmon 380 lift cams
