Can I stretch the inside pivot area of the frame?
  • Hollywoodmx
  • Hollywoodmx's Avatar Topic Author
03 Feb 2013 01:01 - 03 Feb 2013 01:02
#570485
I could use an extra 1/2" for my r1 swingarm. Can I stretch the frame at the inside swing arm pivot area of the frame? Could it break? Could it distort?
Checking first. B)
If your asking how I would either hammer a block of wood or use a hydrolic jack.
- 82 GPz1100injection
- 77 Kz1075 Supercharged
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
Last edit: 03 Feb 2013 01:02 by Hollywoodmx.
  • wireman
  • wireman's Avatar
Re: Can I stretch the inside pivot area of the frame?
03 Feb 2013 01:03
#570486
You would have to cut some crossmembers loose and extend and relocate lots of stuff,id just shorten the swingarm pivot tube 1/4" on each side.
Or you could just find a suzuki gsxr arm,they fit right in there with a couple shims B)
03 Feb 2013 02:11
#570488
Bad idea.
  • bluezbike
  • bluezbike's Avatar
03 Feb 2013 03:16
#570496
Not that I want to diss anyone but why is it a bad idea to stretch the frame out? Just want to know is all
79 KZ 1000 LTD
  • donthaveakawman
  • donthaveakawman's Avatar
03 Feb 2013 03:32
#570497
no
  • zed1015
  • zed1015's Avatar
03 Feb 2013 06:17
#570512
I would avoid it like the plague and definatley not a job to be done at home with a jack, you can't guarantee the frame will spread equally both sides from the center line.
You need a frame jig at the very least.
Jacking the frame apart will most certainly put the frame out of line,the pivot area out of plane and put extreme stress on the surrounding joints.
Also the actual pivot bosses will not move straight outwards but in more of an arc so the spindle will not go straight through either.
Much easier and safer to mod the arm.
The following user(s) said Thank You: wireman, bluezbike
  • Old Man Rock
  • Old Man Rock's Avatar
03 Feb 2013 10:49
#570525
PM Larry C for he had to do that for the ZX7 swing arm in his build...
Yes it can be done... ;)
As with any fab work, will it be a bitch Yup but if done correctly anything can be accomplished...
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
  • KzJim
  • KzJim's Avatar
03 Feb 2013 20:00
#570610
bluezbike wrote: Not that I want to diss anyone but why is it a bad idea to stretch the frame out? Just want to know is all
Stretching something that wasn't meant/designed to be stretched is just a bad idea in general.
If you do manage to stretch it;
Removing what ever mechanical means you used will let the frame return to somewhat of its original state. You will need to 'over-stretch' the frame so when it returns it will have the desired spacing, figuring out what that amount is could prove imposable.
You will need to keep the pivot points on each side parallel so you don't get any bind on the bearings and so the pivot bolt will go thru without having to force it.
And as Wireman said, there will be lots of cutting and re-welding.. a narrower arm would be easier to manage, I put a '99 'Busa arm in my sons '84 gpz project.. I added 2, 1/8" spacers for each side that included compensating for the 'Busas larger pivot bolt and the 17mm of the gpz.
Naiveté in grownups is often charming, but when coupled with vanity, it is indistinguishable from stupidity.
Tis better to remain silent and thought a fool - than to speak up and remove all doubt.
Did ever think that maybe you've been doing it wrong all these years?
  • les holt
  • les holt's Avatar
  • Vendor
  • Vendor
03 Feb 2013 20:05
#570611
I've done it, not really that big of deal but you better be certain your square when done. I go in a form of a z bend to keep the swingarm pivots square and parallel with each other. Braces need cut out and replaced. A jig isn't necessary but HIGHLY recommended.
Les
  • wireman
  • wireman's Avatar
03 Feb 2013 22:57
#570643
As much as he want on about not wantinting to hurt the powder coating on his frame when he got the bike I wouldnt advise trying it! :laugh:
  • Hollywoodmx
04 Feb 2013 04:59
#570691
OK OK I wont stretch the frame. :lol:
I dont need the 1/4 per say but it would have given me a tad more room to work with on the swingarm.
wireman wrote: As much as he want on about not wantinting to hurt the powder coating on his frame when he got the bike I wouldnt advise trying it! :laugh:
Bwaaahahaha!:laugh:
Hey that powder coating is like rock hard! It's better than stock paint! I was beating it up today (by accident) and it didn't even show any blemishes..
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
  • mick z1a
  • mick z1a's Avatar
04 Feb 2013 05:55
#570694
such a shame to be warping these frames when there is a plethora of bolt on parts to take you where you want/need to go.
