76 KZ 900 Front Disk Brakes
  • wireman
  • wireman's Avatar
Re: 76 KZ 900 Front Disk Brakes
11 Jan 2013 23:32
#566929
Ride down a steep as mountain with some twisties in it and tell me how much you love your drum rear brake! :sick: :woohoo:
The single disc front and drum rear were left over from days of the much lighter triples,and they did a piss poor job of stopping them let alone a heavy ass 900/1000.
Take 900 and a 1000 and put identical good rubber and aftermarket shocks on both then take them both up to 100mph and see how much distance it takes to slow both of them down and let me know.
I use rear brake very little compared to the front,but when I do need it Ill take hydraulics over mechanical brakes any day B)
  • Handcannon
  • Handcannon's Avatar Topic Author
12 Jan 2013 14:50
#566999
Will the parts from a 1000 be a direct fit to my spoked rims as far as adding the extra disc, caliper and reservoir?
  • mtbspeedfreak
  • mtbspeedfreak's Avatar
13 Jan 2013 15:05
#567159
wireman wrote: Ride down a steep as mountain with some twisties in it and tell me how much you love your drum rear brake! :sick: :woohoo:
I do every weekend. Google Big Bear, Angeles Crest, Ortega Highway, Palms to Pines Highway, Mulholland Highway, and Palomar Mountain. ;)
2000 ZRX 1100
1976 KZ 900- Daily Driver
  • mtbspeedfreak
13 Jan 2013 15:11
#567160
I do every weekend- its the single largest redeeming factor of living in Southern California. Google Big Bear, Angeles Crest, Ortega Highway, Palms to Pines Highway, Mulholland Highway, and Palomar Mountain. ;)
2000 ZRX 1100
  • wireman
  • wireman's Avatar
13 Jan 2013 15:27
#567164
Handcannon wrote: Will the parts from a 1000 be a direct fit to my spoked rims as far as adding the extra disc, caliper and reservoir?
The hubs are the same,your best/easiest bet would be to find the caliper/brackets from a 78 1000 it should work on the ride side of your forks since theyre reversed.
Unless you want to find a complete brake set up from an ltd bike B)
  • wireman
  • wireman's Avatar
13 Jan 2013 15:29
#567165
Try the same route on a bike with a rear disc brake and compare notes! :laugh:
Ill be in carmel/monterrey on the 23rd this month till feb 6th B)
13 Jan 2013 15:45 - 13 Jan 2013 15:48
#567174
Surprising news:
Attachment 00000_2013-01-13.jpg not found
Last edit: 13 Jan 2013 15:48 by 650ed.
  • wireman
  • wireman's Avatar
13 Jan 2013 15:47
#567176
650ed wrote: Surprising news:
Attachment not found
Good luck,get Aflac! :woohoo:
  • z1kzonly
  • z1kzonly's Avatar
13 Jan 2013 18:18
#567207
Yes they will. As long as you don't mind going away from original parts. And they are cheap on ebay. I always see them going cheap. As long as no one tricks you in to buying a small bore trapezoid master cylinder that is not the 5/8" bore. You need the 5/8" bore for dual discs. I made 4 round 5/8" bore master cylinders last year. Machined them and put new OEM kits in them. Kept 2 then sold 2 on ebay. Gee, strangly enough, I did not make any money off of them?
Good luck with your project!
  • mick z1a
  • mick z1a's Avatar
13 Jan 2013 18:24 - 13 Jan 2013 18:25
#567210
might be some break stuff on offer here, im not sure what calipers/reservoir the ltd's use though. www.kzrider.com/forum/23-for-sale/567111...out-my-kz1000-b4-ltd
Last edit: 13 Jan 2013 18:25 by mick z1a.
