- Thank you received: 7
points vrs electronic
- nobody
- bountyhunter
- Thank you received: 337
- ramtough_63
I appologize for being rude unless there is some wild racing set up that would benefit from it or some new point related injection system that statement should leave your mind or you should buy a mush older version of your bike to increase your level of agrivation in tuning/
1978 KZ1000 A2
Facebook Page
Free Range Custom Art
1982/83 750R/GPZ
1984 Goldwing 1200 Interstate
1982 Yamahopper QT50
Previous
2 79 HD sporty XLH
02 HD FLSTS Heritage
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
and various enduros dirtbikes minibikes...
- RonKZ650
- Thank you received: 240
- nobody
- 4TheKZ1000
- Visitor
nobody wrote: got her running now on points. and it is a cost thing.it will all be ok .and why points and carbs.i under stand them... :huh: :dry: :dry: :dry:
You dont have to understand a Dyna.....you plug in 3 wires, set it in 10 seconds and never need to touch again.....points suck and from the day you set them....which is a pain in the azz.... they are wearing and going bad.... :blink:
The start-up cost to go from points to electronic ignition is an issue and I can understand this as a problem these days.....
- Thank you received: 2829
Glad to see you got it set up. My view is that there are pros and cons to points and electronic ignitions. Points do wear and need to be replaced every 8-10,000 miles, but they generally will not have a hard failure. Electronic is nice because you set it and forget it; but if it fails it will leave you on foot.
Having said that, I wouldn't change my KZ650 from points to electronic because I can easily pop in a new set of points & condensers quickly every few years when needed (because I've had the bike so long and am familiar with the procedure).
But by the same token, I would never consider changing my cars or truck from electronic to points as the electronic is maintenance free and has never left me stranded (yet). :laugh:
- wireman
- Thank you received: 299
And you can have my 8 tracks when you can pry them from my cold dead fingers! :woohoo:
As far as points go yeah theyre a pain to deal with but you can generally file them down enough to limp home as long as yough have access to a screw driver a rock and a match book to gap them with,when electronics goes down you just start walking/pushing! :sick: :woohoo:
- zukdave
- Thank you received: 229
Isn't that like using a crack rock to kick a meth. problem ?
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
- steell
- 4TheKZ1000
- Visitor
steell wrote: At least if you have a points ignition it will still run after experiencing a EMP event from a nuclear bomb explosion
:laugh: :laugh: :laugh: :laugh:
- kzz1king
- Thank you received: 52
Wayne
Home built KZ1000 turbo setup
