points vrs electronic
- nobody
30 Nov 2012 19:49
hi to all.have a 1981 kz1100 can i put points in it,take the electronic out ??
- bountyhunter
Re: points vrs electronic
30 Nov 2012 22:25 - 30 Nov 2012 22:26
There is no technical reason why not. You might need to have a breaker plate drilled to mount the points and consenser. Not sure if there is a mechanical advance unit that could be hijacked from another model? You would need one of those.
Last edit: 30 Nov 2012 22:26 by bountyhunter.
- ramtough_63
30 Nov 2012 22:36
i AM HEAVILY MEDICATED BUT WHY?? the reason for rllecertronic ignition is reliability fist and foremost why wou;d ome wanty to modify somrthin decrease the trliability only. not to mention a the milliion other benetits of electroboic ignition do you plan on putting an 8 track back in your car also?
I appologize for being rude unless there is some wild racing set up that would benefit from it or some new point related injection system that statement should leave your mind or you should buy a mush older version of your bike to increase your level of agrivation in tuning/
1978 KZ1000 A2
Facebook Page
Free Range Custom Art
1982/83 750R/GPZ
1984 Goldwing 1200 Interstate
1982 Yamahopper QT50
Previous
2 79 HD sporty XLH
02 HD FLSTS Heritage
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
Facebook Page
1982/83 750R/GPZ
Previous
2 79 HD sporty XLH
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
- RonKZ650
01 Dec 2012 01:39
The only reason in the world to go back to points would be the huge cost of replacing the failed factory setup. If that is the reason, then possibly Dyna makes an aftermarket setup. Not sure. Otherwise going back to points is like taking the fuel injection off a new car and going back to the old Rochester Quadrajet from 1967. I lived in 1967, and won't go back there in time reliving points and carbs again.
- nobody
02 Dec 2012 11:55
got her running now on points. and it is a cost thing.it will all be ok .and why points and carbs.i under stand them... :huh: :dry: :dry: :dry:
- 4TheKZ1000
02 Dec 2012 12:14 - 02 Dec 2012 12:17nobody wrote: got her running now on points. and it is a cost thing.it will all be ok .and why points and carbs.i under stand them... :huh: :dry: :dry: :dry:
You dont have to understand a Dyna.....you plug in 3 wires, set it in 10 seconds and never need to touch again.....points suck and from the day you set them....which is a pain in the azz.... they are wearing and going bad.... :blink:
The start-up cost to go from points to electronic ignition is an issue and I can understand this as a problem these days.....
Last edit: 02 Dec 2012 12:17 by 4TheKZ1000.
02 Dec 2012 13:00nobody wrote: got her running now on points. and it is a cost thing.it will all be ok .and why points and carbs.i under stand them... :huh: :dry: :dry: :dry:
Glad to see you got it set up. My view is that there are pros and cons to points and electronic ignitions. Points do wear and need to be replaced every 8-10,000 miles, but they generally will not have a hard failure. Electronic is nice because you set it and forget it; but if it fails it will leave you on foot.
Having said that, I wouldn't change my KZ650 from points to electronic because I can easily pop in a new set of points & condensers quickly every few years when needed (because I've had the bike so long and am familiar with the procedure).
But by the same token, I would never consider changing my cars or truck from electronic to points as the electronic is maintenance free and has never left me stranded (yet). :laugh:
- wireman
02 Dec 2012 13:58
Hey Ive got a collection of rochechester quadrajets,some of them are actually really good carbs if youre smart enough to work on them! :woohoo: (Holleys suck! :laugh: )
And you can have my 8 tracks when you can pry them from my cold dead fingers! :woohoo:
As far as points go yeah theyre a pain to deal with but you can generally file them down enough to limp home as long as yough have access to a screw driver a rock and a match book to gap them with,when electronics goes down you just start walking/pushing! :sick: :woohoo:
- zukdave
02 Dec 2012 14:07
Elect. to points.
Isn't that like using a crack rock to kick a meth. problem ?
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- steell
02 Dec 2012 16:42
At least if you have a points ignition it will still run after experiencing a EMP event from a nuclear bomb explosion
- 4TheKZ1000
02 Dec 2012 17:04steell wrote: At least if you have a points ignition it will still run after experiencing a EMP event from a nuclear bomb explosion
:laugh: :laugh: :laugh: :laugh:
- kzz1king
02 Dec 2012 17:58
Points use less juice, you can jump start with points and run on a burnt out fuse!
Wayne
Wayne
Home built KZ1000 turbo setup
