Alternate brake pedals/shift levers?
- donthaveakawman
Re: Alternate brake pedals/shift levers?
22 Dec 2012 20:33
the gpz550 has a different shift lever setup with linkages so you can get the feeling like you are on a crotch rocket.
- guitargeek
22 Dec 2012 21:30My shifter is actually a little different now.seanbarney41 wrote: I dunno, maybe you already saw this...
kzrider.com/forum/5-chassis/171984-ghett...brew-rearsets#171984
Before:
After:
1987 KZ1000-P6 "Ponch"
1979 GS1000 "Dadzuki"
- donthaveakawman
22 Dec 2012 23:28
I guess you flipped the footpegs to the other side, I was considering something of the kind.
Does the stop in there have to be cut and welded?
- Shimmy
02 Jan 2013 18:34
I really have to check back more often - with snow on the ground, I'm not really thinking on two wheels as much.
To answer your question donthaveakawman, I flipped the brackets upside-down on the same side (then flipped the footpegs in the brackets upside-down). Switching sides would mean the footpeg would be above the rearmost of the two mounting holes, whereas I have it behind (same way guitargeek has his in the pics he posted).
Ideally, the stop can be moved to the other side, but I'm reluctant to start chopping away at least until I'm sure of what I want. The shape of the peg behind the pivot prevents the peg from folding downward (take a look and you'll see what I mean), and the stop is just an extra safeguard. So currently the stop is preventing the pegs from folding up - so they're just fixed footpegs at the moment, which I'm fine with for now.
For the shifter side, I took a stock shifter, flipped it backward, and then a couple inches from the shaft, I bent the arm straight outwards to form the new pedal, and cut off the excess. So effectively it's a fairly short lever, backwards. Maybe it's the lazy way, but I like the simplicity of it - maybe since I had a couple years off, I can retrain my left foot.
1980 KZ750 LTD
Edmonton, Alberta
Edmonton, Alberta
- Shimmy
07 Apr 2013 20:35
Whew, finally getting around to posting some pics. Might be a help to others searching around.
So the brake pedal from the EN450 worked out just about perfect (the pedal is a bit closer to the bike than stock, but not hard to use).
And the shift lever is a stock one, flipped upside down, bent, cut off, and ground down a bit to fit the rubber.
Hopefully I can get on the road to test it all soon!
Attachment STA50004.JPG not found
Attachment STA50002.JPG not found
Attachment STA50003.JPG not found
1980 KZ750 LTD
Edmonton, Alberta
Edmonton, Alberta
- kzz1king
07 Apr 2013 20:54
I used a shifter from a Kawi Concours. It works so slick,easy to do and looks non ghetto! The shortened brake lever, a little ghetto. Pics in build thread in sig.
Wayne
Wayne
Home built KZ1000 turbo setup
- Shimmy
18 Apr 2013 19:06
Interesting, I might try that if the shortened lever is too much effort or if the reverse shift pattern is annoying. Good to know that one works; unfortunately I don't have a ton of parts just lying around to mock up or ability/tools to modify things significantly, so knowing something works "out of the box" is handy!
1980 KZ750 LTD
Edmonton, Alberta
Edmonton, Alberta
- kzz1king
18 Apr 2013 22:19
I happened to have the parts handy amd was very pleased itworked so well.I would love to have access to a MC wrecking yard but none around here.
Wayne
Wayne
- donthaveakawman
19 Apr 2013 00:32
what about fashioning the rear footpegs forward, maybe on the aluminum mount that holds them on?
- Shimmy
20 Apr 2013 10:27
I thought about using those mounts, but it seemed the brake pedal would probably interfere with the exhaust. The flipped brackets put the pegs in just about a perfect position.
1980 KZ750 LTD
Edmonton, Alberta
Edmonton, Alberta
- havakaw
20 Apr 2013 17:33
If you are still using the stock front forks,drop them in the clamps about an inch.It makes a WORLD of difference!!!
'80 KZ 750 LTD-H
'82 KZ 1100 A-2 Shafty (ex-bagger)
- Shimmy
20 Apr 2013 18:25
Unfortunately the handlebars are in the way of dropping the forks in the clamps, but what I did do was remove the spacers in the forks, which dropped them a good 2-3 inches. I put in thicker oil so it doesn't bottom out with the reduced travel (I'll be experimenting with levels and air pressure once I can test it). I'll make some shorter spacers if the fender touches the exhaust under load or if it's too low. Visually and as far as riding position though, it seems good.
1980 KZ750 LTD
Edmonton, Alberta
Edmonton, Alberta
