Which swingarm?
  • Robber
  • Robber's Avatar Topic Author
Which swingarm?
30 Oct 2012 08:47 - 30 Oct 2012 08:56
#556350
Hi,
Because I fitted CBR-SC28 Fireblade front forks with the corresponding front wheel on my kz, I would like to see the same wheel
Attachment Achterwielcbrsc28.jpg not found
in the swing arm. Can you guys help me out in choosing the right duo shock swing arm? The Honda SC28 swing arm pivot is to wide so I was hoping to find one that fits the frame without to much modifications.
:whistle: Yes I know, I'm a lazy bastard :whistle:
Bikes, Babes, Bass guitars
Last edit: 30 Oct 2012 08:56 by Robber.
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
Re: Which swingarm?
30 Oct 2012 09:33
#556355
welcome.
ew,
rough call on anything close to bolt in to fit that wheel. :pinch:
then you wanna throw dual shocks in there :woohoo: .
your best bet (imho sir) is going to be try to match your axle size up with a early ninties gsxr or 03/04 zx636.
or give yor dimensions to someone that can custom build you whatever you want :whistle: .
  • 531blackbanshee
  • Vendor
  • Vendor
Re: Which swingarm?
30 Oct 2012 10:38 - 30 Oct 2012 10:43
#556371
just found your intro thread.
what would be wrong with cutting the ends off your current swingarm and welding in ends that match the wheel you want to use?
then just weld some shock mounts on for dual shocks and your set.
i added in extended ends in dougs old gsxr swingarm.here is the thread,
kzrider.com/forum/11-projects/105593-my-...=20&start=200#553931
Last edit: 30 Oct 2012 10:43 by 531blackbanshee.
  • Robber
Re: Which swingarm?
30 Oct 2012 12:43
#556382
The point is that the old suzuki swing arm is not wide enough for a 170 - 180 tire. It holds a 150 at the moment with only 4mm space between the tire and the drive chain.
  • NakedFun
  • NakedFun's Avatar
Re: Which swingarm?
30 Oct 2012 13:37
#556388
Well, you can go with a ZRX1100 or 1200 arm. It will still take some work to fit it, but I don't know your laziness / effort threshold! :woohoo:
Cory
2008 Kawasaki Concours 14
1999 Kawasaki ZRX1100
1976 Kawasaki KZ900
  • StreetfighterKz
  • StreetfighterKz's Avatar
Re: Which swingarm?
30 Oct 2012 23:09
#556475
Robber wrote: The point is that the old suzuki swing arm is not wide enough for a 170 - 180 tire. It holds a 150 at the moment with only 4mm space between the tire and the drive chain.
What old Suzuki swingarm are you referring to?
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
  • myelr21
  • myelr21's Avatar
Re: Which swingarm?
02 Nov 2012 20:51 - 02 Nov 2012 20:55
#556844
zrx swingarm. gsxr1100? 02 gsxr1000 its not as wide and you just have to space it then weld shock mounts. my thought when i was going to monoshock mine was to machine some new bearing mounts and weld them into each side of the swingarm then use the original z bearings and caps and pivot bolt.
07 zx1400 candy blue pc3 dual staintunes.
project z1000j, gpz1100 engine, 1400 big block mtc, kerker with race baffle, 37mm keihin cr specials, gsxr1100 usd front , gsxr 1100 monoshocked rear.
Last edit: 02 Nov 2012 20:55 by myelr21.
  • !!a2k!!
  • !!a2k!!'s Avatar
Re: Which swingarm?
05 Nov 2012 20:14
#557161
I think I have a full rear end without the wheel for a cbr f3. The wheels look the same but Im not sure if you are in the states. They are monoshock and I think a 160 wheel
galfer brakes
jbseatz
c4-revolutions
racetech suspension
Motydesign.com lightweight batterys
