1976 KZ 900 (GS1100 Swingarm / LTD Mag) upgrade
- K.D. HART
24 Oct 2012 17:24 - 24 Oct 2012 17:42
I already know what I want to do, but need a little help with the parts needed.
I want to make this.
kzrider.com/gallery/gallery-categories/g...ork-in-progress-2744
I have the 1976 KZ900. I think I found a 1981 GS1100 swingarm and Kerker 4 into 1 header.
My question is, what LTD rims are needed??
1. Should I go with the 1000 LTD rims on front and back? (Captain Z is running a 160 rear tire?)
2. Will I have speedo problems?
3. "Sprockets" Are they interchangable and what do I need?
4. Will the dual calipers mount to my stock single caliper forks?
5. Anyone seen this Captain Z bike? I'd like to see how the caliper was mounted to the rear swingarm.
Any help with this "specific" info would be greatly appreciated.
P.S. I seen a bracket for sale not long ago on ebay. You could remove the rear fender and mount the tail light and licence plate to this bracket up under the duck bill, but I can't seem to find them now?
kzrider.com/forum/11-projects/594694-dir...to-kz1000-now#638488
kzrider.com/forum/11-projects/591120-i-f...rbo-drag-bike#606286
kzrider.com/forum/11-projects/589806-197...750-suspension-build
Last edit: 24 Oct 2012 17:42 by K.D. HART.
- mark1122
- Keep twisting it
Re: 1976 KZ 900 (GS1100 Swingarm / LTD Mag) upgrade
24 Oct 2012 17:54 - 24 Oct 2012 17:56K.D. HART wrote: I already know what I want to do, but need a little help with the parts needed.
LTD rims r 16" so unless u want the low rear look, u may want an18" rim from the other kx modles.
unless u change the front wheel diameter then yes u will have a read error.
if u stay with a 630 chain this should not matter. just get the right sprocket for the donor wheel.
yes , both of your forks should have caliper mounting tabs. if u swap the forks to the oposite side, u can mount the cals behind the forks. i think it looks better that way. jmo.
No i have not.
hope this helps.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Last edit: 24 Oct 2012 17:56 by mark1122.
- K.D. HART
24 Oct 2012 22:24
No eBay APP ID and/or Cert ID defined in Kunena configurationFound the fender eliminator, but for this price I think I could make my own.
