Steering stops on fork swaps
- StreetfighterKz
18 Oct 2012 10:17
Hey all,
I figured that this would get more exposure and help out more people here than in my project thread.
For those of you who aren't following my thread, I've swapped in a '95 Gsxr750 on my '76 900.
The stock Gsxr fork stops were not going to work so I machined them off and smoothed out the lower triple tree. I also removed the stock steering stop from the 900 frame as obviously it wouldn't work either.
Here's the question...
Should I add one tab to the frame and two stops to the lower clamp OR two tabs to the frame and one stop on the lower clamp.
Both options are about the same as far a labor goes but I just wanted others opinions.
Thank.
Later, Doug
Thank.
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
Re: Steering stops on fork swaps
18 Oct 2012 11:14
which will be more invisible?
- StreetfighterKz
18 Oct 2012 11:26
They'll both be in front of the steering head tube so same visibility/invisibility.
Later, Doug
Later, Doug
1979 z650 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
- NakedFun
18 Oct 2012 15:43
Bolt two stops, one on either side of the stem, on the lower triple and weld a single tab on the steering tube for the frame. That way you can place the tabs exactly where you need them. Just my.02
Cory
Cory
2008 Kawasaki Concours 14
1999 Kawasaki ZRX1100
1976 Kawasaki KZ900
1976 Kawasaki KZ900
