wheel bearing
Last edit: 23 Jan 2013 00:57 by martin_csr.
- donthaveakawman
Re: wheel bearing
24 Oct 2012 21:45
as i put the old bearing back in i also had a spare set of EBC brake pads that just happen to fit all around the bike 2 disks in the front and one in the back. :woohoo: . the old ones are not too shabby but somewhat low.
so with the break-in period for the brake pads listed on the package- ie- go easy on them through town for xxx amount of miles, does that have any leeway if i only replaced one side?
I usually downshift on the freeway or use the back brake while turning, so i have replaced the back one twice and the front ones hardly get used.
also i know i am going to need a new brake master cylinder for the front, as one of the screws was stripped and it was my fault as i was drilling and prying i had to glue it on to keep it from leaking.
so long story summarized i have more meat on the brakes and more brake fluid is in the master cylinder without ventilation.
- wireman
Re: wheel bearing
25 Oct 2012 03:40Yes a large socket can be used,if you can find a shop in your area that builds/rebuilds large cat construction equipment see if they have an old collection of differant size intake and exhuast valves theyre tossing out.donthaveakawman wrote: thanks for the heads up i will try to find a more suitable tool for next time, some sort of socket?
They come in handy for driving many differant sizes bearings/seals
- wireman
Re: wheel bearing
25 Oct 2012 03:42Looks like a trip odometer on the bottem to me anyway,try pushing in the little black button and see if it resets to zerodonthaveakawman wrote:Attachment 76574_235118956615381_1259832115_n.jpg not found
i don't know if it was that many miles since the last oil change or what, any help would be nice.
- wireman
Re: wheel bearing
25 Oct 2012 03:53Find a big empty parking lot and practice using your front brakes more,they have a lot more power than the rear brake for slowing you down.donthaveakawman wrote: as i put the old bearing back in i also had a spare set of EBC brake pads that just happen to fit all around the bike 2 disks in the front and one in the back. :woohoo: . the old ones are not too shabby but somewhat low.
- donthaveakawman
- donthaveakawman
Re: wheel bearing
25 Oct 2012 22:42wireman wrote:Find a big empty parking lot and practice using your front brakes more,they have a lot more power than the rear brake for slowing you down.donthaveakawman wrote: as i put the old bearing back in i also had a spare set of EBC brake pads that just happen to fit all around the bike 2 disks in the front and one in the back. :woohoo: . the old ones are not too shabby but somewhat low.
it seems like the front ones are useful for stop lights anyways, that way i am not balancing on one leg.
- donthaveakawman
Re: wheel bearing
25 Oct 2012 22:43 - 25 Oct 2012 22:45wireman wrote:Looks like a trip odometer on the bottem to me anyway,try pushing in the little black button and see if it resets to zerodonthaveakawman wrote:Attachment 76574_235118956615381_1259832115_n.jpg not found
wierd/weird( i before e except after c, but i am still being spellchecked
Last edit: 25 Oct 2012 22:45 by donthaveakawman.
- donthaveakawman
Re: wheel bearing
01 Nov 2012 21:10
I re greased the caliper moving parts the reason i put thread-locker on the bearings before is one of the cir-clips broke but is still usable, Martin CSR you were right should have greased them for installation. whatever they're paying you, i can tell them to double it.
- donthaveakawman
Re: wheel bearing
01 Nov 2012 21:12
< spins in computer chair with cat on lap and says " No JB Weld i expect you to die" followed shortly with laughter then the cat ripping into his face with sharp, dirty claws.
- donthaveakawman
Re: wheel bearing
04 Nov 2012 17:07
i was going to write that the inner round thing that goes between the bearings and around the axle had a cone shaped retainer to keep it in place.... but quantum of solace just came on tv so i will keep that to myself.
- donthaveakawman
Re: wheel bearing
04 Nov 2012 23:04
With the amount of grease to repack those things and taking into consideration that they were probably original, The new ones don't need to be repacked. I should replace the back ones also.
