79 kz front end swap to zx11
- steell
Re: 79 kz front end swap to zx11
18 Nov 2012 02:10
I think it's 9 1/4" between the frame rails at the pivot.
The following user(s) said Thank You: Landfair
- wireman
18 Nov 2012 02:21
Yep just measured 2 of them right at 9.25"
- lushbaugh
- everybodys a pro......
18 Nov 2012 02:51
landfair i have a black powdercoated stock length kz swing arm for disc brake if you wanna work out a trade exchange numbers and ill send pics monday
79 kz1000 ltd all apart
the best advice i can give is dont take dnthavakawmans advice..
- les holt
18 Nov 2012 10:44
I have all ready made up front tubes for the arms. I don't usually finish the bearing bores till last, after the arm is welded up. Things do tend to move around a bit during welding and by finishing that last you have less of a chance of getting a bad alignment with the bearings.
Les
Les
76 kz 900 turbo
77 LTD 1000 turbo
2 78 Z1R's
72 H2
76 kz 900 turbo
77 LTD 1000 turbo
2 78 Z1R's
72 H2
- Landfair
18 Nov 2012 17:44
You have them made up as in I could buy one off of you? I dont think i have the capability of doing it on my own.
06 Ninja 650r
76 kz900 motor and parts 80 kz1000 frame (project)
Ktm 520 supermoto
01 katana (for sale)
Ktm 520 supermoto
- les holt
18 Nov 2012 17:57
I make them a little long and undersize on the bearing diameter. After fully welded I set them up, square the ends and line bore the bearing holes. They are 1-3/8" diameter. I can supply you with one or install if needed. Interested, PM me.
Les
Les
76 kz 900 turbo
77 LTD 1000 turbo
2 78 Z1R's
72 H2
76 kz 900 turbo
77 LTD 1000 turbo
2 78 Z1R's
72 H2
- Landfair
18 Nov 2012 18:08
Ill pm you
06 Ninja 650r
Ktm 520 supermoto
Ktm 520 supermoto
- uglee
- New 2da game but Tru 2this thang!!!!!
28 Nov 2012 09:36
Have u looked at this product?
www.americanclassix.com/swingarmKJSA900_180.html
This Les guy does badazz work but hasn't pm'ed me with a quote yet
- Landfair
01 Dec 2012 18:58
I actually bought a stock swing arm and was gonna extend it and widen it myself but found a KOSMAN extended widened swingarm on Craigslist for only 120! Im gonna buy it so if anyone needs a swingarm I will have 2 extra. 1 is stock with bushings and swingarm bolt and the other is an extended 6 inch swingarm without bushing just bolts on if you need one to make hard tail.
06 Ninja 650r
Ktm 520 supermoto
Ktm 520 supermoto
