- Thank you received: 676
Moving upper shock shock mounts?
- DoctoRot
But ultimately I don't want half-assing it at this stage to present problems latter. Most shops i have talked to about doing this want way too much to do this, but i suppose they have some crazy-ass jig that they would do it with.
Any advice on how to approach this would be appreciated. here is a photo of how it sits now.
- wireman
- Thank you received: 299
- zed1015
- Thank you received: 1554
You need to make a basic jig that puts the top shock mounts in exactly the same position both sides regardless of the new subframe accuracy.
Use two bars that overlap using the swingarm spindle and swingarm shock mounts as the bottom corners to triangulate the new top shock mounts position.
Hope i've made that simple enough to be understandable without a diagram ?
Will be easy once you figure out what i mean.
- DoctoRot
Well that will be a perk of doing this, but when we cut the old subframe off we also cut off the swing-arm mounts, so i figured it would be easier to put them in the tube than fabricate some sort of bracket to hold it to the frame.wireman wrote: Are you trying to gain ground clearance by relocating the shock mounts?
zed1015 wrote: That looks like nice work
Very clever, very easy. I like. I think you mean something like this? any other tips for us when I'm helping my buddy get this done?
- zed1015
Yes! that's it,
Once you've figured the right position for the mount tack the bars together so it won't move and you can quickly transfer it to the other side or make an identical pair then using an adjustable cross bar you could set up both of the mounts at the same time for width also.
Lots of possibilities here.
- Thank you received: 797
zed1015's is much more appropriate for a one off project tho.
but i thought it couldn't hurt to look at this one.
- DoctoRot
- mark1122
- Keep twisting it
- Thank you received: 109
Just thought mention it.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- damarble
- Thank you received: 13
I don't like what it did to the handling so I plan on shorter shocks to lower the back down again.
BTW the under brace on your swinger looks great.
Go green, buy a Kawasaki!
82 KZ750M CSR Build Thread
89 ZX600C Streetfighter
- mark1122
- Keep twisting it
damarble wrote: I moved mine forward. I cut out the old studs, made brackets out of tube, drilled to slip the studs in tight, tacked brackets to piece of angle steel to keep them square and dropped into place, aligned with tape measure, welded and ripped of angle brace.
what dont u like about the handling?
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- damarble
- wireman
