Moving upper shock shock mounts?
- damarble
Re: Moving upper shock shock mounts?
10 Oct 2012 11:29
Good point. Buy why make mods if you don't do it better that the original?
Go green, buy a Kawasaki!
82 KZ750M CSR Build Thread
89 ZX600C Streetfighter
- wireman
10 Oct 2012 12:30
I know Im just saying that the fancy jigs are definateloy overkill for something that can be done with a couple good levels and a tape measure.
if your swingarm is straight and shocks are both same length thetres your jig right there
- OnkelB
10 Oct 2012 16:22
I'm pretty sure that Sanctuary jig serves more purposes than just installing shock mounts - from all the holes and various mounting points on it my guess is they also use it for building swingarms, modding the rear frame, check alignment etc.
77 KZ 650 B1, 82 GPz 1100 B2.
- NakedFun
10 Oct 2012 18:04
I made up a simle jig that bolted on to the rear stock mounts, then bolted in my new mounts, and held them in place on the frame where I wanted them. Used a machinist square and caliper to ensure they were true, and voila, ready to weld. You have removed the original rear frame section so this wouldn't be an option for you.... Just my .02
Cory
Cory
2008 Kawasaki Concours 14
1999 Kawasaki ZRX1100
1976 Kawasaki KZ900
1976 Kawasaki KZ900
