Sprocket ratio suggestions
  • kzz1king
  • kzz1king's Avatar
Re: Sprocket ratio suggestions
02 Oct 2012 17:48
#552036
C'mon, why are you guys dragging your feet ;) My brakes aint on. Whats a safe rpm for cruising?
Wayne
Home built KZ1000 turbo setup
02 Oct 2012 20:39
#552077
1000 rpm under red line ought to provide an ample margin of safety.
The 24 hour speed-record guys probably stay at or near red line most of the time.
What's the desired cruising speed?
Good Fortune! :)
  • kzz1king
  • kzz1king's Avatar
02 Oct 2012 22:56
#552113
I ride my Concours on any long trips. The A is used on poker rides and such.About 200 mikes in a day at 60-70. The other problem is there is not gas in every town around here so as speed goes up range will go down. Might just switch to a 14 and try that first.
Wayne
