Sprocket ratio suggestions
  • wireman
  • wireman's Avatar
Re: Sprocket ratio suggestions
24 Sep 2012 18:03 - 24 Sep 2012 22:59
#550647
:sick:
Last edit: 24 Sep 2012 22:59 by wireman.
  • WABBMW
  • WABBMW's Avatar
  • Let The Good Times Roll !
24 Sep 2012 18:25 - 24 Sep 2012 18:28
#550651
A 16 / 40 with a 530 chain is equivalent to a 13 / 33 with a 630 chain.
On my '82 KZ650, a 14 tooth front sprocket is as large as will fit, when using a 630 chain. Stock gearing on my bike was 13 / 33.
The 1000 motors apparently have a little more room around the countershaft sprocket.
I recommend changing to a 13 tooth front; adjusting the chain slack and see how you like it.
Bill Baker
Houston, Texas
1982 KZ650 CSR
2008 Yamaha FZ1
2006 Yamaha FZ1
1977 Honda Supersport 750 four (sold)
1984 Honda Nighthawk 650 (sold)
Last edit: 24 Sep 2012 18:28 by WABBMW. Reason: additional info.
  • 4TheKZ1000
  • 4TheKZ1000's Avatar
24 Sep 2012 22:52
#550689
Im running a 630 - 14/37 way to much grunt...spins a 150x18 tire in 1 and 2 pretty easy....if I hammer on it can get 3rd to break loose also. Im going to drop to a 15/35
  • 4TheKZ1000
24 Sep 2012 22:52 - 24 Sep 2012 22:53
#550690
double post
Last edit: 24 Sep 2012 22:53 by 4TheKZ1000.
  • KZ1000inaus
  • KZ1000inaus's Avatar Topic Author
  • Luminous Red KZ1000 A2
24 Sep 2012 23:42
#550709
wireman wrote: Double posting $#@$^ computer! :sick:
i just thought you were just trying to make a point :-)
  • kzz1king
  • kzz1king's Avatar
24 Sep 2012 23:49
#550713
More like a fourple point :woohoo:
Home built KZ1000 turbo setup
  • wireman
  • wireman's Avatar
24 Sep 2012 23:57
#550717
:woohoo: :woohoo: :woohoo: :woohoo:
i dont have enough patience when it doesnt post right away i just pound on the button till something happens! :woohoo:
  • KZ1000inaus
25 Sep 2012 00:01
#550720
wireman wrote: :woohoo: :woohoo: :woohoo: :woohoo:
as long as that's all you're pounding on whilst online that's OK :laugh: :laugh: :laugh:
  • 4TheKZ1000
25 Sep 2012 00:04
#550721
he said pound the button hehheeehe..... :woohoo: :woohoo: :woohoo: :woohoo: :woohoo:
  • KZ1000inaus
25 Sep 2012 00:18
#550729
wireman wrote: 16/40 530 B)
Z1 Ent dont have a 40 tooth 530 :-(
what other combination would be the same with available sprockets?
www.z1enterprises.com/ListItems.aspx?nam...01010104010211010000
i'm too much of a thicky to use that gearing commander app thingy.. i did try !!
  • wireman
  • wireman's Avatar
25 Sep 2012 06:23
#550747
I want to say its the same gearing as a 78 kz650 sr or something like that,I can call the guy who sold me the parts later today to get you a part number if you need it. B)
  • kzz1king
  • kzz1king's Avatar
01 Oct 2012 22:35
#551887
I have been looking at the gearing commander site and really enjoying it. I am running a 16 in rear (77.5 circumference) with a 15/33 combo. It is not bad but I would like more low end grunt. Stock Z1 gearing with stock tire puts you at 80mph @5100 rpm 15/35 and 14/33 with current tire put me at 75mph @ 5100. A 14/35 puts me at 71 at 5100. (630 chain )
I dont do long distance rides with this. 2oo miles in a day would be max. I do like to take it out and crank on it good though. What is a safe cruising rpm for these motors?
Wayne
