swingarm swap
  • kzbobber91
  • kzbobber91's Avatar Topic Author
swingarm swap
07 Sep 2012 06:08
#547219
i was wondering if a el250 swing arm will work on my kz440 im bout done with my bobber and im wanting to stretch it so i can have more room to sit my seat back cause i heard that it will stretch it 6 inches if anybody can help me out thanks for any input
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
Re: swingarm swap
07 Sep 2012 13:10 - 07 Sep 2012 13:10
#547287
u need to measure the width of the el swingarm at the pivot and compare it to yours.
also check the pivot bolt size against yours.
Last edit: 07 Sep 2012 13:10 by 531blackbanshee.
  • zukdave
  • zukdave's Avatar
Re: swingarm swap
07 Sep 2012 22:38
#547391
First thing is do you have a EL250 swing arm ?
If not get one you can try and see what needs to be done to
make it fit.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
  • kzbobber91
Re: swingarm swap
08 Sep 2012 01:20
#547423
i seen someone on her sayin it will work but the pivot point was just a lilbit wider than my frame ive asked everyone on ebay the measurements but i got no replies so i went ahead and purchased one today and see how much wider it is if i got alot to do ill just send it back if yall can find the measurements for me i would gladly apprichate it before it get to my doorstep
  • zukdave
  • zukdave's Avatar
Re: swingarm swap
08 Sep 2012 13:23
#547483
I'll put a tape on my stock arm and let you know.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
