Bolt supplier
  • Topper
  • Topper's Avatar Topic Author
Bolt supplier
18 Aug 2012 18:52
#543307
I've got need of an unusually sized bolt. I've tried the local hardware stores, auto stores and the local specialty fastener place with no luck. Google/Amazon/Ebay and Yahoo searches also turned up nothing. I'm wondering if such a bolt exhists. Maybe one of you can help.
I need an M7 90mm bolt, preferably with a hex head on it. Any suggestions?
Permanent and perpetual noob.
1979 KZ750 Twin
2009 Kawasaki Versys
  • mtbspeedfreak
  • mtbspeedfreak's Avatar
Re: Bolt supplier
18 Aug 2012 19:13
#543312
I go to McMaster-Carr ( www.mcmaster.com/ ) when I need something odd or in bulk.
2000 ZRX 1100
1976 KZ 900- Daily Driver
  • Topper
Re: Bolt supplier
18 Aug 2012 23:14
#543336
Thanks for the great links. I haven't checked all of MFolk's links, but I've checked 4 of them and McMaster's. I don't think anyone makes what I'm looking for.
In M7s McMasters longest screw is 50mm. In M6 they go up to 150mm and in M8 to 200mm. No one seems to make long M7s though.
I was hoping to avoid a helicoil or timesert, but I think I'm out of luck.
1979 KZ750 Twin
  • wireman
  • wireman's Avatar
Re: Bolt supplier
18 Aug 2012 23:38
#543339
Could you drill retap your part for an 8mm bolt? B)
  • ramtough_63
  • ramtough_63's Avatar
Re: Bolt supplier
18 Aug 2012 23:58
#543344
try a BMW auto dealership part number 13537603841 M7x90 fuel injection bracket bolt have no clue what pitch it is but it lists for 3.00 i googled it lol
1978 KZ1000 A2
Facebook Page
Free Range Custom Art
1982/83 750R/GPZ
1984 Goldwing 1200 Interstate
1982 Yamahopper QT50
Previous
2 79 HD sporty XLH
02 HD FLSTS Heritage
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
  • Topper
Re: Bolt supplier
19 Aug 2012 00:20
#543349
wireman wrote: Could you drill retap your part for an 8mm bolt? B)
No, there's not room for a 8mm bolt.
ramtough_63 wrote: try a BMW auto dealership part number 13537603841 M7x90 fuel injection bracket bolt have no clue what pitch it is but it lists for 3.00 i googled it lol
You had a lot more luck with Google than I did. I'll check that out. Thanks!
1979 KZ750 Twin
Re: Bolt supplier
19 Aug 2012 00:41
#543351
Any possibility of tapping for and using a 1/4" bolt?
Good Fortune! :)
  • PFD
  • PFD's Avatar
Re: Bolt supplier
19 Aug 2012 03:52
#543371
I would buy an 8mm longer than you need, a 7mm die and figure out a way to cut the 8mm thread to a 7mm thread. I've done it with non metric screws, it's not much of a step down in size. With some good tap cutting fluid ill bet the 8mm bolt will go right in the 7mm die and you'll be in buisness. You'll just need to make sure you get the proper pitch and size die to cut the thread you are trying to match.
If it won't fit the 7mm die without taking off some of the thread, I'd put the 8mm bolt in a lathe and turn it down a hair or put it in a drill press and run a file on it while it's spinning. Once it's the right dia. you can cut the 7mm thread easily.
Just my 2 cents...
78 Kz1000A2, 77 Cb750K daily rider, pinstriper and signpainter
  • Topper
Re: Bolt supplier
19 Aug 2012 09:48
#543386
Patton, That would probably work, but I'd prefer to not put SAE bolts on unless I have to. It just seems wrong somehow ;)
The BMW part ramtough_63 found actually looks perfect. I'll call the local dealership on Monday and if they can't get it, it looks like there are plenty of suppliers online.
1979 KZ750 Twin
