GS1100 E swingarm swap on KZ900
- sled
31 Jul 2012 04:41
I know it has been asked before and i have searched the forum.
I have the oportunity to get one of these what the concensus? worth it I have a KZ900 would like to retain the drum brake and and put a 160 tyre on (3.5 - 4) rim. Anyone done this with drums
any assistance is appreciated thanks Jason
- Mercury Kid
Re: GS1100 E swingarm swap on KZ900
02 Aug 2012 21:25
I cut the brake stay off the top and welded a new one to the bottom for the drum. Mixed and matched some spacers from the local junkyard, GS axle. I just bought a 3.5 wheel and plan on adding a 160 tire as well. May need to pie cut the gussets and weld them flat to the inside of the arm to fit, not sure yet. Flipped the brake arm up and custom linkage. Not hard if you have fab skills or access to a shop. Otherwise, use a disc wheel and mount a MC, much less fab, but not as cool.
'76 KZ900-Z1 clone
Z1 70's period longbike
- sled
04 Aug 2012 06:04Mercury Kid wrote: I cut the brake stay off the top and welded a new one to the bottom for the drum. Mixed and matched some spacers from the local junkyard, GS axle. I just bought a 3.5 wheel and plan on adding a 160 tire as well. May need to pie cut the gussets and weld them flat to the inside of the arm to fit, not sure yet. Flipped the brake arm up and custom linkage. Not hard if you have fab skills or access to a shop. Otherwise, use a disc wheel and mount a MC, much less fab, but not as cool.
Hey Mercury Kid thanks for the reply i ended up getting the swingarm with both axles and spacers haven't fitted it yet as waiting new rims to arrive for 160 tire. Do you have any photos of your setup??? would like to see some close ups
enjoy the weekend
- Mercury Kid
06 Aug 2012 22:01
Sorry, don't have any pics. Mine isn't very well done, as I did it all in steps, so I didn't plan for the larger tire when making my stay. I'll have to put a jog in it, as well as in the brake linkage, which is a bit flimsy and doesn't work well at the moment anyhow. Oh well, always a work in progress.
'76 KZ900-Z1 clone
- BohicaBob
06 Aug 2012 22:52
Years ago I upgraded my '73 Z1-900's wheels to DID 2.15" x 19" and 3.00" x 18" rims and SS spokes/nipples and beefed up the stock swingarm and kept the rear drum setup.
In 2006 I upgraded this bike's wheels to Excel 3.5" X 17" and 4.25" x 17" rims with radial tires and an '83 GS1100 swingarm and scrapped the rear drum setup. The rear disk setup is much better.
- Hollywoodmx
11 Nov 2012 12:57BohicaBob wrote: Years ago I upgraded my '73 Z1-900's wheels to DID 2.15" x 19" and 3.00" x 18" rims and SS spokes/nipples and beefed up the stock swingarm and kept the rear drum setup.
I'm looking at the upgraded spoke wheel option as well, for the KZ hub would one want the 32 or 36 hole wheel?
- 82 GPz1100injection
- 77 Kz1075 Supercharged
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
- DoctoRot
- Hollywoodmx
11 Nov 2012 13:40 - 11 Nov 2012 13:41DoctoRot wrote: the kz1000 has 40 spoke wheels
Doh! Ok Thanks!
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
Last edit: 11 Nov 2012 13:41 by Hollywoodmx.
